What is #8 NPT?
/ What is #8 NPT? #1
JudeHey
VA
TYM T3025
I'm looking at an SAE to NPT adapter on Summit Hydraulics, they offer NPT size as choices as #8 NPT or #10 NPT. I thought they came in fractional sizes.
Can anybody explain please?
Thanks
/ What is #8 NPT? #2
Is this the adapter you are referring to?
This is from a #10 SAE/ORB (o-ring) to a 3/8" npt.
Also pipe can be refered to as the # of sixteenths
with a #8 being 8/16th or 1/2"
The ORB fittings are mostly referred to by the same system,
/ What is #8 NPT?
No, but the chart helps.
Thanks
/ What is #8 NPT?
This is what i was looking at.
/ What is #8 NPT? #6
Hydraulic fittings are pretty much sized this way across the board. JIC, ORB, ORS and NPT as well. What are you building, repairing, etc. that you are using a bulkhead fitting on? When mounting in brackets, or through cab or enclosure walls they work well for being able to securely mount solidly. Here is your fitting on Amazon. Here also is a link for a Good reference to find the fittings you need. The other thing is that with some minor changes like an added letter or two fittings use standard part numbers as well.
/ What is #8 NPT? #7
The screen shot does not agree with itself. It calls out 3/8 Jic x 3/8 NPT -- That would be 6 - 6. ....... Then it says its an 8-8.
I think that website is not updating as it should as you make choices. I would get on the phone to make sure of what I was getting.
/ What is #8 NPT? #8
I get the bulkheads sometimes if I need to increase the connector length.
/ What is #8 NPT? #10
It's updating, they just have it labeled poorly. Here's a link to the item in question. Adapter, JIC Male x NPT Bulkhead
/ What is #8 NPT? #11
It's still a bit confusing. The end that runs through the bulkhead with the securing nut would be a straight thread, however they say it's NPT which is tapered. It's possible that it's a blended thread with taper at the end and straight for the nut, assuming that actually works. I agree that it's worth a call to find out what that end really is.
