Surface Oxidation Increases Electrical Fire Risks
/ Surface Oxidation Increases Electrical Fire Risks #1
Stratoflyer
Chesapeake Bay Virginia
Kubota BX23S
ENSURE TECHNICAL UNDERSTANDING/QUALIFICATION AND REMOVAL OF POWER AT CIRCUIT BREAKER PRIOR TO DOING ANY ELECTRICAL DEVICE INSPECTION OR REPLACEMENT.
I recently encountered a potential electrical fire risk associated with my home clothes dryer. This incident could manifest with most any higher current devices such as electric dryers and electric stoves/ranges that utilize 220 volts alternating current (Vac). Even lower voltage high current devices may be subject to this type of failure mode. Gas ranges may be susceptible to this risk for those that use 220 Vac to heat the oven. Without going into all the details, in a previous life I had occasion to wear the hat of that of a Mishap & Accident Investigator, so I had to scratch the itch nagging at me to understand the root cause. From my cursory examination, user manuals and electrical codes either fail to mention this or adequately throw caution to conditions that can pose these kinds of risk.
Namely, Surface Oxidation can lead to increased contact resistance that in turn creates hot spots produced by localized off-nominal power dissipation.
P watts=(I^2 amps)(R ohms).
One evening while running the electric dryer, an odor not unlike that of burning plastic became noticeable and upon turning off the dryer, that odor soon dissipated. The odor was that of melting plastic. Upon further investigation, the below photos show what I discovered.
Initial examination of the dryer plug showed one leg of the 220 circuit plug contact (nearest in photo) having oxidation over entire surface and scorched arcing burns about the tip. Removal of the wall receptacle revealed melting of the plastic housing most pronounced about the 220 contact associated with the oxidized/burned dryer plug.
You might be saying, ” That can’t be! My dryer only pulls 26 amps and the plug and the receptacle are rated for 30 amps!” True, but keep in mind whatever assurances this gives is only good for nominal operating conditions.
Quick back-of-the-envelope estimate of what I encountered after measuring plug-receptacle contact resistance of 15 ohms was around
19,140 watts. Wow...that’s hot. Granted, the actual thermal initiator most likely occurred when the contacts went into an arcing phase as set up by the oxidation. And the initial onset of oxidation likely led to more rapid cascading by the heating of the entire set of contacts, but I haven't tried to replicate that. Good subject to explore for an enterprising STEM student.
Cause and Solution? I live on the Chesapeake Bay in Virginia. House is 70 feet back off the water. Lots of wind...lots of salt laden air that
everything is exposed to, which no doubt accelerates oxidation faster compared to more benign environments. Older installations should also be examined for oxidation, no matter their location. My installation was less than ten years old but was exposed to a lot of salt air.
Replacement of plug and receptacle with every exposed contact getting a thin layer of Ox Gard will hopefully mitigate future occurrences
To further scratch my curiosity as to fires attributed to electrical sources, I ran across the following U.S. statistics. *Fire departments responded to an estimated average of 46,700 home fires involving electrical failure or malfunction each year in
2015–2019.
• These fires caused an estimated average of 390 civilian​
deaths and 1,330 civilian injuries each year in 2015–2019, as​
well as an estimated $1.5 billion in direct property damage a​
year.​
• Electrical failures or malfunctions were the second leading​
cause of electrical home fires in 2015–2019 accounting for​
13% of home structure fires.​
• Three in ten fires (30%) involving electrical failure or​
malfunction occurred in the cold weather months from​
November through February.​
• Arcing served as the heat source in over three in five fires​
(63%) of home fires involving an electrical failure or​
malfunction in 2015–2019.​
electrical-fires​
/ Surface Oxidation Increases Electrical Fire Risks #2
I'm glad that turned out well for you! Was your wiring ok? I've had one "plastic smell" that we couldn't locate, and cut the power, but it was too late and the fire broke out at 2am. Lots of damage despite the fire department being literally around the corner. We had one that we did locate the issue in time at a different place.
Have you considered dielectric filled wire nuts as well? Personally, I also check the circuit breakers and main panels bus for corrosion, and I assume external corrosion on a breaker means internal corrosion and out it goes...I believe that some, but not all, service panels allow approved dielectric compounds on the contacts.
When I was responsible for maintenance on a house that close to salt air, the receptacles and switches were on a regular replacement schedule, and unused outlets got baby proofing covers. These days, I'd probably buy the tamper proof outlets to keep things sealed. I also used the foam air tight seals on the cover plates to try and reduce salt infiltration.
Much as I like being near the ocean, that experience gave me an appreciation of wear items in homes that close to the ocean, rather like living on a boat, but without the stainless, and NEMA4X wiring.
All the best,
Peter
All the best,
Peter
Thanks for the additional info Peter. I've had no problems since. You're spot on about paying attention to breakers...anything handling higher current loads. I lived in the midwest most of my life and yes I love the Saltlife. But it brings with it unique aspects that require attention that those further inland may not have to worry as much about. I put this online here for those who don't normally think about such things. Those conveniences mounted in the wall that we don't normally see...out of sight, out of mind. Hopefully more folks will become aware of these hidden risks and become more proactive with mitigating the risks. Originally this was a writeup I did for family and friends (oldest son lives in Deerpark, TX southeast of Houston, a few feet from the bay). All your insight and suggested options are great! Best...David
/ Surface Oxidation Increases Electrical Fire Risks #4
My experience is that in near ocean and marine environments salt spray /salt dust has a way of getting everywhere, making lots of items that are considered durable in the Midwest are disposable items with short lifespans.
For non-electrical items, I used to, and still do, use Fluoramics products, e.g. Hinder-Rust to slow down corrosion on unpainted metal surfaces.
There may be better coatings around now, but those coatings really spaced out my replacement intervals. YMMV.
All the best, Peter
/ Surface Oxidation Increases Electrical Fire Risks #5
I've read quite a few stories as well about the 14R-50 receptacles being used for electric vehicle chargers. Apparently they're brand name receptacles but they're not rated for a continuous high current draw such as you'd get charging a vehicle.
/ Surface Oxidation Increases Electrical Fire Risks #6
View attachment 5504163View attachment 5504164
2015–2019.
year.​
electrical-fires​
Also, circuit breakers are rated at 80% of stated value for continuous, prolonged use, such as a 240VAC clothes dryer. That is why the circuit breaker did not trip-out, yet the receptacle melted. The normal cause of this in the RVing world is the springy contacts in the receptacle were worn out, which it turn caused poor contact between the plug and receptacle.
/ Surface Oxidation Increases Electrical Fire Risks #7
Yeah, we now tend to use a Specification Grade receptacles for EVs.
Samples:
/ Surface Oxidation Increases Electrical Fire Risks #8
For EVs, I think that is definitely worth the cost in my book. I did the same here.
And/or upgrade the circuit so that the EV is pulling less than 80% of the circuit rating, or intentionally set the EV charge rate to be less than the 80% of the circuit rating.
All the best,
Peter
/ Surface Oxidation Increases Electrical Fire Risks #9
I’ve run into one melted 120v circuit breaker and 2 melted dryer outlets over the decades in rental property.
Also accompanied by burning plastic odor…
/ Surface Oxidation Increases Electrical Fire Risks #10
Even electric meter sockets aren't immune from this. Came across this at a work site maybe 20 years ago...
/ Surface Oxidation Increases Electrical Fire Risks #11
@Oaktree Was that one of a series of meters? The upper wiring/busbar configuration looks interesting.
All the best, Peter
Great posts to all you who've contributed. You've certainly added more to my toolkit of things deserving more attention. I worked as a EE in another life, but only low voltage stuff for instrumentation and telemetry applications. The gotcha's with higher voltages and currents is something I didn't much worry about until this dryer plug/receptacle incident. Peter, didn't answer your ealier question...no damage to the wiring other than slight arc scarring and some melting of sheath near the bare wire-contact. Had plenty of slack so I just cut it back maybe three inches and stripped end for shiny clean clad on wire. Did that with all the leads at the receptacle. Then as I mentioned previously, everything got a coating of Ox Gard. One other thing...it made me a bit paranoid about what's hidden behind the walls elsewhere to where I did a visual inspect of all the other suspect installs to seek out discoloring/signs of oxidation. Didn't find any problems but it certainly drives home the need for periodic inspections. Best...
/ Surface Oxidation Increases Electrical Fire Risks #13
Again, two items in the FWIW bin:
1) A non-contact IR thermometer or FLIR camera can be a quick way to check devices when under load to find things that are hotter than they should be. (e.g. outlets, switches, etc.)
2) I don't know where your AHJ is on codes, but if you have doubts about things, there are arc fault circuit interrupter (AFCI) breakers and combination GFCI/AFCI breakers.
All the best,
Peter
