Need help bending trailer jacket bracket
/ Need help bending trailer jacket bracket #21
the only problem with the front hole, alot of times thats too close for the tailgate......no one wants a smashed tailgate
/ Need help bending trailer jacket bracket #22
How do you attach this to the trailer. Do you have to weld a small piece of pipe to the side of the frame and then this jack slips over it? Hard to tell from the pictures.
Lighter versions are a bolt-on arrangement, like single-axle trailers only.
/ Need help bending trailer jacket bracket #23
/ Need help bending trailer jacket bracket #24
It looks like from your pictures the the angle the jack is welded to is no thicker that 3/16 of an inch. I have several stout C clamps that could pull the angle back to the trailer frame, where it could then be welded. This would probably not leave the jack perfectly straight but it would be close. Tugging on the jack to straighten the angle won't work. So either remove the jack from the angle and use a new piece of angle or draw the angle up to the trailer frame with stout clamps and weld it in place. Before you go through all that trouble though please make sure the jack operates properly over the full travel. Just my 2 cents.
Eric
  • Good Post
Reactions: D&D
/ Need help bending trailer jacket bracket #25
You could get a shorter jack and add a drop leg
/ Need help bending trailer jacket bracket #26
I would not use the jack as an anchor point to lever thing back into position, instead I'd put a couple of big pipe wrenches on either side of it and use cheater pipes with come-a-longs to pull things vertical (actually just a tad beyond) then reweld. Or, as mentioned above, if the jack is close enough to be hit with the tailgate, it might be advisable to cut that mount out and get a longer piece so I can be set back enough to not interfere. That would be my option for a long term keeper.
/ Need help bending trailer jacket bracket #27
Once something has been bent like that, it's like putting toothpaste back in the tube. You might try all sorts of things, but never achieve a satisfactory result...and may just wreck the jack, as others have observed. Cut the piece out and rebuild it. It'll be quicker overall and you'll end up with a better product in the end. (You need not ask me how I know :cool:)
/ Need help bending trailer jacket bracket #28
Guess you've never witnessed what happens in body shops, let alone seen people create new flawless body panels from sheets of steel, or even aluminum.
Steel like that jack mount is very easy to work with, and it'd almost be hard to end up spending more than 30 minutes fixing the problem. Part of that time being spent on letting the welds cool so paint can be applied.
/ Need help bending trailer jacket bracket #29
Lots of heat and a sledge hammer
/ Need help bending trailer jacket bracket #30
I bent my trailer jack by driving over a stump and the bottom of the jack hit the stump and bent the jack bracket backwards. I have been able to grind out the welds on the ends of the bracket and clean them up but I don’t know how to bend the thick steel bracket back to its original position. You can see where the front edge of the bracket has separated about 1/2” from the bottom of the side rail. I have beat on it with a sledge hammer, tried to bend it with a lever, etc but I can move it. Anyone have any ideas how to bend this thick steel bracket back? ThanksView attachment 5336824View attachment 5336825View attachment 5336826
OK, stupid idea here but why not hook the trailer to your truck, take a floor jack and bend it back into place then weld? Won't be perfect but it'll do the job I'd think.
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2015 International ProStar T/A Day Cab Truck Tractor (A64556)
2015 International...
VERMEER BC1000 XL BRUSH CHIPPER (A67147)
VERMEER BC1000 XL...
2009 BOBCAT T190 SKID STEER (A65053)
2009 BOBCAT T190...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
