grsthegreat
Super Star Member
the only problem with the front hole, alot of times thats too close for the tailgate......no one wants a smashed tailgate
Lighter versions are a bolt-on arrangement, like single-axle trailers only.How do you attach this to the trailer. Do you have to weld a small piece of pipe to the side of the frame and then this jack slips over it? Hard to tell from the pictures.
The jack that I linked to folds up, thereby minimizing the risk of bending it. Since the OP has welding capabilities, and needs a new jack anyway, why not upgrade?Well if I was gonna abandon that jack, I would just get an a frame jack and bolt it in the other hole.
3000 lbs. 16" Side Wind Trailer Jack Round Tube 796875 [300369]
surpluscenter.com
You could get a shorter jack and add a drop legthe only problem with the front hole, alot of times thats too close for the tailgate......no one wants a smashed tailgate
www.ordertrailerparts.com
Guess you've never witnessed what happens in body shops, let alone seen people create new flawless body panels from sheets of steel, or even aluminum.Once something has been bent like that, it's like putting toothpaste back in the tube. You might try all sorts of things, but never achieve a satisfactory result...
