Jd auto connect mower
/ Jd auto connect mower #2
I believe that yes they will but would suggest checking deere parts website using serial numbers for the two tractors to verify linkage is the same or deck part numbers are the same.
/ Jd auto connect mower #3
The deck on a 1025r is the same as my 2025r but the change over happened a year or two later for the 1025r. 2220 is about the year the change happened. I couldn’t find a very good picture of mine installed but I have a picture of the deck. It has a long heavy front draft arm that is different then the old style.
/ Jd auto connect mower #4
Dodgeman
Do you know if anything changed on the tractor side or was it just front hanger on mower? That is the part I am unsure of.
/ Jd auto connect mower #5
Dodgeman
I’d also say things changed on the tractor side also but am not sure about that. You can see JD parts on line but I’m terrible at navigating it.
/ Jd auto connect mower #6
I tried looking at Deere parts but I think need tractor serial number to confirm what parts fit which years. I think the deck will interchange but would have to check with dealer to confirm that is correct.
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2014 Peterbilt 337 S/A 18ft. Cab and Chassis Truck (A64194)
2014 Peterbilt 337...
2015 Polaris Sportsman 570 AWD ATV (A64557)
2015 Polaris...
2019 Chevrolet Tahoe SUV (A64194)
2019 Chevrolet...
2011 Ford E-250 Cargo Van (A64556)
2011 Ford E-250...
3147 (A63117)
3147 (A63117)
