Compact pull behind wheel driven manure spreader
/ Compact pull behind wheel driven manure spreader #2
No familiarity with that or any spreader. I did go to the website and looked at it. Isn't it odd that the description is short on real quantifiable characteristics? "Recommended for 1-5 stalls" doesn't translate well to cubic yards or pounds of capacity for me. The dimensions SOUND like it is fairly large, but my guess is they use the same measuring method office trailer rental places utilize - tip of the tongue to the extreme other end. The l-o-n-g tongue makes it sound BIG :)
/ Compact pull behind wheel driven manure spreader #3
My buddy has that spreader. With 2 horses it was an every day event to dump the spreader. Now, with 3 horses and a pony it gets dumped at least once a day.
I prefer Millcreek spreaders. I’ve had mine a really long time and last season I needed some parts. No problem. Buy used if possible, prices on new are :eek:
/ Compact pull behind wheel driven manure spreader #4
The small one is 8 cu ft
/ Compact pull behind wheel driven manure spreader #5
/ Compact pull behind wheel driven manure spreader #7
We have been using a Loyal manure spreader for 16 years. Pulled it behind the Mule for years, now behind the Kubota RTV-X. Holds 6-7 muck buckets of manure. Easy to maintain, grease it once a year and spray the chains. Did buy new tires last year due to weather cracks in the old ones starting to not hold air. A little bit of Slime solved that, so we now have spare tires.
I don't need big. The 350-HD holds around 10 5gallon buckets. I don't have my own livestock with manure to handle frequently and get aged manure for free from local folks by bringing my 5gal buckets and filling up with a shovel at my convenience. Yes, the length includes the tongue. I'm 71, living alone with arthritis and it's getting too painful trying to spread evenly by hand. It's also more time consuming by hand. I'm just using it for my large gardens. I also like that it's mostly stainless with no chains to maintain and repair. I grew up in this rural area of central New York State with family dairy farms (typically 50-100 cows) as neighbors. Now the farms are factory style (24/7 milking 1000+ cows) with no pastures or fences, big slurry pits, slurry sprayed every spring, etc. I am very familiar with older real manure spreaders but that isn't what I need.
Thanks for the Mill Creek link. They look nice but bigger than what I need and I assume more expensive.
Thanks. This looks like something that could work for me but it's larger which I don't need. It doesn't say it's made with stainless steel though which is a negative. The Newer 350-HD has flat-free tires which is a plus to me. I wish they had in stock at Tractor Supply so I could look at it.
/ Compact pull behind wheel driven manure spreader #11
I looked at the newer ones, but felt the old style (1940’s?) was better built and had better spreading ability. I found a guy that remodels old units, and got it for less than new ones. Mine is either pulled by my team or by the kawasaki mule, depending on how i feel. I do like making the horses spread their own waste though. i dont spread every day...i do it 2-3 times a year. i have a manure pile so it can compost before spreading.
/ Compact pull behind wheel driven manure spreader #12
Went to the web site for local dealer that handles spreaders. Currently they are out of stock. New batch of local politicians has bought up all his stock.
This was just too hard to pass up.........
LOL
/ Compact pull behind wheel driven manure spreader #14
Please provide make, model and pictures
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
USA KB057-48" HYD BRUSH CUTTER (A65053)
USA KB057-48" HYD...
Large Gun Safe (A64557)
Large Gun Safe...
2012 INTERNATIONAL DURASTAR 4300 SBA 4X2 CHIP TRK (A63276)
2012 INTERNATIONAL...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
Bear Statue (A64557)
