New member signing in
/ New member signing in #1
Big Muddy
Mahindra 3016 Shuttle
Was clued to this forum from a fellow member on a firearms board after posting a thread on a hydraulic problem with a Mahindra 3016 Shuttle. Found out how to check fluid levels but now I'm trying to figure out how to remove the shaft from the brush hog attachment so I can take the tractor to the experts to figure out why I have now power to lift the brush hog off the ground and why the front end loader moves glacially slow.
/ New member signing in #2
Are you talking the pto shaft where it connects to the tractor? If so sometimes there is a spring loaded button you have to press in as you pull the shaft loose. Some also have a collar you slide to get the shaft loose.
/ New member signing in #3
Welcome to TBN...enjoy.
Yup, I figured it out after watching a you tube video. I knew it was something simple but I couldn't remember, and for the life of me I can't find where I hid the manual for the brush hog. Also found out the hydraulics and the transmission share the same reservoir, and the fluid level is full, but it can't lift up the brush hog, so I'm taking it to the dealer to repair tomorrow.
/ New member signing in #5
Has the fluid ever been changed? Almost all of them have a hydraulic filter and a lot also have a screen, these can become plugged.
I'm wondering about the filter as well. I thought they changed the transmission fluid when I had it serviced last year. I know they didn't change the filter. Have about 200 hrs on the unit.
/ New member signing in #7
and enjoy the forum!
Thanks for the welcome guys!
KMC 13 SHANK H.C. CHISEL PLOW, 3PT (A64278)
KMC 13 SHANK H.C...
Pallet of 8ft Metal Roofing (A65583)
Pallet of 8ft...
2010 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2010 Ford F-250...
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2008 Chrysler Sebring Sedan (A64194)
2008 Chrysler...
2000 Ford E-350 Shuttle Bus (A64194)
2000 Ford E-350...
