Sharpening chainsaws
/ Sharpening chainsaws #1
anthony1
Meadville, Pennsylvania
kubota bx24
I don't really enjoy sharpening chainsaw chains. Does anyone have tips on sharpening as well as a good file? Also does anyone use carbide tipped chainsaw chains. Were they worth your money? Thanks!
/ Sharpening chainsaws #2
Check out the Stihl/ Pferd 2 in 1 files, makes quick work of filing and is pretty easy to do. As for carbide chains, if you dont enjoy sharpening you will really hate carbide.
/ Sharpening chainsaws #4
I use this thing, there is a guide for the angle, and you can't screw the depth it works pretty good for me. As for file I am not sure a file is a file but I think I use Oregon. I simply buy lots, I am not scared to throw it out and grab a new one.
/ Sharpening chainsaws #5
I've never been very good at sharpening chains with a file. My results were always mediocre.
However, I discovered using a battery powered Dremel tool with diamond embedded bits. Correctly sized to the chain, I can get very sharp chains with very little effort. It's almost fool proof. Just go slow, as the bits can be aggressive when new/ fresh. This practice has been a game changer for me. And it's fast.
Good luck
/ Sharpening chainsaws #6
I use one like @Rockbadchild shows. I also have a small flat file and a gauge for lowering the rakers. It all came as a kit from Stihl. I’m about 75% with my sharpening. I get good chips but also a little sawdust, which means some of the teeth are less than perfect. It helps if I actually use a magnifying glass to look at them afterwards. I think sometimes I’m a little low on the tooth with the file. I improve the more I do it.
/ Sharpening chainsaws #7
Dremel has a chain sharpener kit. It's an end cap with a guide plate to hold angle and I think 2 different size stones. Well worth the money! I take that and a power inverter when away from the house. Also have a HF chainsaw grinder that I can run fr9m the inverter. Dremel is quicker and use grinder at end of the day to even everything up!
/ Sharpening chainsaws #8
Another note about the Dremel bits. I have only used the diamond embedded bits, which work well. I read that the stone bits deteriorate quickly, usually before completing a single chain. Something to consider...
/ Sharpening chainsaws #10
I've always used a Dremel type tool (different brand, same thing) with a 6 mm pink stone. The stone lasts a long time for me and always get very good results.
/ Sharpening chainsaws #12
I have a Harbor Freight grinder, it does a good job. I do like the idea of the Dremel method though. And I should real try to get proficient at using a file. But I always have at least 2 sharp chains with me so I have never run into a situation where I needed to do it.
/ Sharpening chainsaws #13
I'm with you. I gave up on filing on the bar, change chains and grind with the HF grinder in the shop.
/ Sharpening chainsaws #14
I've found this to be better than using a dremil tool. And that's just my opinion.
/ Sharpening chainsaws #15
This (Husqvarna) used to be my favorite
This is my new favorite. Five hand filing touch ups, then off to the shop.
/ Sharpening chainsaws #16
I just carry spare chains, and quickly swap them out as needed. I'd rather sharpen while listening to the radio on a random rainy Tuesday night in my heated shop, than burn daylight doing it outdoors on Saturday.
I keep several chains in each size, and when they start to really pile up, I'll set aside an evening or rainy day to plow thru a dozen or more. A bench-mounted chain grinder makes quick work of it, in reasonably skilled hands, but can also wreck a whole bunch of chain really fast in the wrong hands. :ROFLMAO:
/ Sharpening chainsaws #17
I didnt like it as well. Tried everything i could get my hands on, the Dremel works fast and makes them look sharp, BUT for some reason in my experience chain dulls really fast
Then i bough Pferd files, now i love sharpening chains and saws are happily throw long big chips and i need to touch up the chain not more often than every 3-4 tanks unless i hit a nail or a rock. And even then Pferd makes it easy task. I dont use any gadget, only a file with wooden handle, Ones in a while i tough up rakers with a flat file.
My wood it read oak 100%.
/ Sharpening chainsaws #18
I used to sharpen chains free-hand; got pretty good at it finally.
Decided to file down drags free-hand. Chain was verrrry agresssive as a result. Then it grabbed in a big Oak; broke the chain and I think it broke the flywheel key. Haven't gotten around to taking it apart since I stopped burning wood.
I intended to fix it this last winter but sickness kept me in the house most of the winter. If it wasn't me it was DW, and since her stroke I'm a caregiver now. Everything else is second place.
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
Caterpillar 70in Loader Forks and Frame Attachment (A61572)
Caterpillar 70in...
Massey Ferguson Hesston 1745 (A64126)
Massey Ferguson...
Kuhn GWD44 (A64127)
Kuhn GWD44 (A64127)
Wooden Indian Statue (A64127)
Wooden Indian...
2023 Case TV450B (A62177)
2023 Case TV450B...
