Trailer Build
/ Trailer Build #1
KennyG
Super Member
SW Michigan
John Deere 2320
Here is another project I probably spent more time and money on that it's worth, but it was a fun project. I had a solid S-10 pickup bed left over from another project so I decided to build it into a trailer. I also has some heavy wall 2x2 tubing and that was enough for the frame rails and tongue.
I thought about trying to find a cheap used axle but the truck bed requires specific dimensions and I'm not that confident in my welding and fabrication skills, so I bought a 3.5K axle with the right configuration. As a bonus it has the same wheels and tires as my car hauler so I use one as a spare if I need one.
After I put it together, I realized the axle placement did not provide much tongue weight. Since I couldn't move the axle, I found some 2x3 tube and added some weight to the tongue and added a base for a tongue mount tool box.
/ Trailer Build
Painting was a real learning experience. In the past I've usually used Rustoleum for these kinds of projects and two stage urethane for valuable stuff. I primed the frame with Rustoleum clean metal primer and the bottom of the bed with rusty metal primer. Then I painted those with Rustoleum gloss black.
For the bed, I decided to try Majic paint from Tractor Supply, mainly because they have the matching reducer and hardener there. I like to use hardener when I can because I have a fresh air hood setup.
I followed the instructions (for a "perfect spray" and sprayed the bed and go horrible orange peel. I sanded it back down, put in 50% more reducer and got orange peel again. Once more I sanded it and this time doubled the recommended reducer. This time it went down pretty smooth with very good gloss. I think with a little rubbing and polishing and I think it will look fine.
/ Trailer Build #7
Looks great! Any idea of the weight? Guessing maybe 500?
/ Trailer Build #12
Nice...very nicely done. (y)
/ Trailer Build #14
The next time you do some painting check out how fast the thinner dries, They make different thinners for different air/environment conditions.
/ Trailer Build
They do for the expensive urethane paints but Majic seems to have only one reducer which I would guess is probably mostly mineral spirits. If I recall they say don't use acetone which I have used in the past with other paints.
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
John Deere 2680H (A64126)
John Deere 2680H...
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63688)
2015 GMC 3500HD...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
Exmark C2-96 (A64127)
