Convert your pin attach to universal mount (SSQA).
/ Convert your pin attach to universal mount (SSQA). #1
walnutman
Gold Member
Ben Wheeler, TX
Yanmar YT359C, John Deere 310SE
/ Convert your pin attach to universal mount (SSQA). #2
Unless you're switching attachments every day, it's a waste of money & labor IMO. I can switch my pin-type bucket and forks attachment in 20-30 minutes, and I'm 83.
I plan out my work for the week and organize bucket work and forks work grouped so frequent changing is unnecessary.
BTW, the facebook page doesn't work properly for me; a phone is not a replacement for a movie camera IMO.
It allows you to use other attachments that don't have the same style.
You could buy a used attachment that is SSQA and just use it.
/ Convert your pin attach to universal mount (SSQA). #5
I agree. The same can be said for pin mount too. Since I have pin mount, it would be expensive to switch, then have to convert present attachments.
/ Convert your pin attach to universal mount (SSQA). #6
To each their own. Having tried both, I will never own a tractor without a SSQA.
I cheaped out and bought my tractor with a pin mount bucket figuring I wouldn;t have occasion to switch much. After grumbling about it for years, I finally decided to switch. My wife gave me the tractor side of the SSQA attachment for Christmas. I debated having the "ears" cut off my bucket and a SSQA plate welded on. Ended up just buying a new SSQA bucket and selling the old one.
If I'm not messing with hydraulic connections, I can easily make a swap in under a minute. Hooking up the hydraulics when swapping in my grapple doesn't add much time.
I do a lot of swapping in the winter, switching between my forestry grapple (getting logging done when the ground is frozen) and the bucket (for scraping ice off the driveway and other general purpose work). Messing with a pin-on swap in the really cold weather was a pain in the butt. Even in the summer, the convenience of the quick swap makes it so much easier to get jobs done efficiently.
/ Convert your pin attach to universal mount (SSQA). #7
I wouldn't give up my SSQA. I switch between a bucket, forks and a grapple. I'm 75 and switch in a couple of minutes. And that's the long version for grapple hydraulic connections.
Count me in , modified my first Rhino tractor from pin on to QA, and have multiple attachments, then bought the TLB and another Rhino.
Over the winter bought the conversion pieces for the mods so all three can accept any attachment.
QA or bust!
/ Convert your pin attach to universal mount (SSQA). #8
Wait until you find out about forks that adjust hydraulically. But a SSQA front end loader is basically a necessity.
/ Convert your pin attach to universal mount (SSQA). #9
If you have multiple implements and multiple machines SSQA is the only way to go. Years ago, I converted our TC40DA to SSQA to switch between the bucket, pallet forks, and a hay spear. I have SSQA on all three of my tractors and now the CTL. I changed the hydraulic couplers on my hay grapple and brush grapple to 1/2" so I can use them on the CTL, freeing up my WM75 mowing tractor from grapple work. The pallet forks, hay spear, and any of the 4 buckets work on any of the four machines. The backup hay grapple still has 3/8" couplers for the WM75 tractor.
/ Convert your pin attach to universal mount (SSQA). #11
Probably true for folks who are only ever going to use two attachments and don't change them very often. If you wanted to go buy a different attachment though, your choices are limited. I have at least 8 different attachments for my machine (all SSQA that I built) and it's quite common for me to change them several times a day. I can also go borrow something different from a neighbor. I wish that we (the US) had standardized around the Euro QA style, but we didn't, so SSQA it is.
/ Convert your pin attach to universal mount (SSQA). #12
That is another great point. There is actual competition in QA attachments prices, proprietary designs not so much.
If you decide to change or upgrade, there is decent demand for standard SSQA to be able to sell on the used market.
/ Convert your pin attach to universal mount (SSQA). #13
Except for the BX25D the tractors have SSQAs and I use them very often.
Had to convert this loader to be able to run a snowblower meant for a skid steer, so now I can also use pallet forks, buckets, and other things, on this stronger loader.
/ Convert your pin attach to universal mount (SSQA). #14
I only have the factory bucket, and added forks ... No way I'd be without SSQA, if another tractor or attachment comes along that doesn't have it, it will be adapted!
I also added a quick attach setup for my backhoe bucket, I now have three other "tool ends" that pop on there!
If more than one tool will fit on, it's getting a quick and easy way to swap it out, that why I also have a quick hitch on the three points on both tractor's!
/ Convert your pin attach to universal mount (SSQA). #15
YES.
The tractor implements and stock FEL mounts can and will resist.
But Resistance is Futile.
They WILL be Assimilated into the SSQA Hive.
2025 Hydraulic Drum Mulcher Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2002 OilMens 76R 4,200 Gallon Commercial Truck Trailer (A61573)
2002 OilMens 76R...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
