Yanmar 155d Radiator shock absorber?
/ Yanmar 155d Radiator shock absorber? #1
Flemdog377
Pueblo West, Colorado
Yanmar 155D
Looking to see if any one has leads on replacement radiator shock absorbers for a yanmar 155D. I looked up the part number and i can find it but they are from Marine sites, are $36 a piece and have no pictures to verify its what I need. So does anyone have recommendations on alternates or locations to get a few that aren't $36 for a thicker rubber washer?
/ Yanmar 155d Radiator shock absorber? #3
IF you can not find a match for size then reach out to Brand-M.
@AaronM is more than helpful over there.
And come join us over in the Yanmar section here.
/ Yanmar 155d Radiator shock absorber? #4
/ Yanmar 155d Radiator shock absorber? #5
Do you have a hole saw for your power drill? If so, it is easy to make rubber shock absorbers.
When I want a rubber shock absorber I go down to Ace Hardware and buy a one foot square sheet of 1/4" thick black rubber - it's probably Buna-N. Then cut as many discs out of it as needed to stack to the final height.
The pilot drill on the hole saw cuts the ID, and the hole saw the OD. Stack as many as are needed.
Oh I reached out to him the other day about injection pump shims since I think mine have a leak. As for the forum section, I don't know how I missed it, its where I think I would've placed most of my questions had I looked and saw it, thanks for pointing it out
/ Yanmar 155d Radiator shock absorber? #7
Hm. Depot! Cheap and various sizes. Common for swimming pool stores also.
/ Yanmar 155d Radiator shock absorber? #8
I'd look at sway bar end bushings at the local NAPA. Take it with you, so you can try to match a size. They may have dimensioned drawings on the website.
Also, look online industrial suppliers for isolator bushings.
2014 FORD E-350 11 PASSENGER VAN (A65643)
2014 FORD E-350 11...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
First Choice GM30-72 Finish Mower (A66408)
First Choice...
New/Unused Wolverine Quick Attach Tree Spade (A65583)
New/Unused...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
