ase drain location? LS Mt774
/ ase drain location? LS Mt774 #1
OrangeJbird
NW WI
3320 w/300cx FEL
where would I install a case (zero pressure return port) drain on MT774?
/ ase drain location? LS Mt774 #2
There should be a plug on the bottom of the transmission/axle to drain it. there may be multiple drain plugs too. I have no experience with that model but my TYM has 3 drain plugs for the hydraulic fluid draining, The LS MT240HE has just one if I recall.
/ ase drain location? LS Mt774 #3
The smaller models have a plug on the rear of the left axle housing where you can add a zero pressure return line, not sure if an MT7 would have it there or not. I'll look at one and let you know what I find.
I’m talking about a return port for excess oil from a hydraulic motor to return to the reservoir.😎
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
Mini Universal Grapple (A65640)
Mini Universal...
2020 John Deere 470G Hydraulic Excavator (A64553)
2020 John Deere...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
