3140 FEL lifting capacity
/ 3140 FEL lifting capacity #1
Usafexplorer
Midwest
LS XG3140
Anyone know the actual lifting capacity of the FEL on a 3140? Tried searching the innerwebs and getting a host of answers. I have pallet forks and a 850# counterweight on the 3 point, I need to offload a 2200# piece of freight. Any experiences or info is greatly appreciated.
/ 3140 FEL lifting capacity #2
Quick search results:
The LS XG3140 compact tractor features a loader lift capacity of approximately 2,088 to 2,189 lbs (depending on the loader model and measuring point) and a 3-point hitch lift capacity of 1,808 lbs. This 40-horsepower tractor is designed for high-capacity material handling and versatility, with a total hydraulic flow of 13.7 GPM.
Key Lift Capacities for LS XG3140 (approximate):
L3112 Loader
2189 lbs lift (full at pin)
992 kg
3338 lbs breakout (at pin)
1514 kg
52° dump
18.6 inches reach (dumped)
47 cm
41° rollback
94 inches height (at pin)
238 cm
63.9 inches clearance (dumped)
162 cm
weight: 728 lbs*
330 kg
Bucket width: 66 inches
167 cm
Appreciate the reply, I found this info as well and wasn't sure what "full at pin" meant. Either way that is really close to my freight amount, I guess we'll give it a try and see how it goes.
/ 3140 FEL lifting capacity #4
That's 2190 lbs at full height at the pivot pivot where the quick attach pivots from. Anything forward of this pivot pin will only reduce that capacity and don't forget the weight of the forks will only reduce that capacity further.
You also don't have enough counter weight for that kind of lifting. Ideally about 1200 to 1500 lbs in counter weight to make it at least safe.
All valid points, thanks!
/ 3140 FEL lifting capacity #6
Be careful moving really heavy stuff around on pallet forks. Front wheel bearings are one of the weak links in the chain, something I had never considered until I damaged one on my 4047H.
2008 Ford F-350 Pickup Truck (A61573)
2008 Ford F-350...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2022 Mercedes-Benz Sprinter 1500 Cargo Van (A61573)
2022 Mercedes-Benz...
2023 CATERPILLAR 326 LONG REACH EXCAVATOR (A62129)
2023 CATERPILLAR...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
