Three Point Hitch Depth Control
/ Three Point Hitch Depth Control #1
Keuka
I recently purchase a 2025 BX2380 with rim guard weighted rear tires and a front end loader. I'm researching additional rear ballast options and contemplating purchasing a box blade for both grading and ballast. I have experience operating a three point hitch positioning valve but no experience with a 1/4 inching valve. My research says the 1/4 inching valve, after setting implement depth, will slowly bleed off when using heavy implements. This results in the box blade slowly drifting lower during operation and this makes box blade grading a real challenge. Question: Will closing the three point hitch speed control valve, located beneath the seat, rectify this problem?
/ Three Point Hitch Depth Control #2
As long as the seals in the 3 pt hitch cylinder are good, yes, closing the flow control valve with kept it from dropping at all. It should still let it raise at full speed.
It's one of those things that you'll only know after use. It might leak down a lot or not even be noticeable during use.
Thanks for the reply. This is a brand new tractor so there should be no problem with a leaking seal. That's exactly what I was thinking. I assumed the speed control knob closes a hydraulic fluid return valve and locks the implement from lowering further.
/ Three Point Hitch Depth Control #4
I have a 400+ lb winch on the 3 point hitch and it will remain in whatever position I left it in for weeks. I've used other tractors that do drop down.
/ Three Point Hitch Depth Control #5
"Should". I fought leak down on all 3 remotes on my L4060 from day 1. The dealer replaced several & finally put a DPCV on one to mitigate it. Granted that was valve leakage, but you can't be guaranteed of 0 leak down on hydraulics. Closing the 3pt knob should take care of things though.
With 1,100 hours on my L4060 & a heavy flail mower in the 3pt I notice the 3pt raise up 1/4" or so every 20-30 minutes if the machine is idling. Presumably it's sagging that much in the same time, but that's less noticable than it bumping it back up to set height
/ Three Point Hitch Depth Control #6
Kubotas are notorious for remote leak down.
Amazing that Kubota has not yet addrerssed this.
Thanks for the replies. After additional consideration, I've decided to go with a woods GS54.30 grading scraper instead of a box blade. The scraper should do everything I require. It will also be simpler to operate with the limited functions of the 1/4 inching valve. For additional ballast, I'm considering buying and customizing a three point hitch carry all frame. I can design it specific to my needs, add weight, carry tools and work in more confined areas than I could with a box blade hanging off the back. Thanks again for the input.
Bobcat 873 (A55272)
Bobcat 873 (A55272)
Zero Turn Mower (A59231)
Zero Turn Mower...
NEW HOLLAND LB75 BACKHOE (A63291)
NEW HOLLAND LB75...
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
Pittsburg 4 row cultivator (A64119)
Pittsburg 4 row...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
