PT425 winter traction
/ PT425 winter traction #1
jwangelin
Member
Glenwood, NY
Bolens HT20
So I finally made it out in the 425 today to move some wet piles, it did a quicker job than I expected. The 60" plow worked very well but the weight of the snow created a traction issue. I have turf tires and an asphalt drive that is starting to blow apart. What have some of you snow state PT owners done for a little extra traction? Lower tire pressure? Chains? Rubber tire chains? Loaded tires?
Thanks in advance,
Jon
By the way, I kept having problems getting the PT started, I reset the valves a couple times and nothing. I did remember people saying the robin was cold blooded. I charged the battery up and heated the hydro/oil tank and it started right up.
/ PT425 winter traction #2
I don't have turf tires (R4 loader tires), but asking turf tires to function on snow and loose gravel/asphalt seems like it is a big ask to me. My R4s are pretty good, but on soft material, or loose gravel on slopes, they need help, and I use net chains, as suggested by @SpringHollow. Have you looked at what is available for your tire size?
All the best,
Peter
/ PT425 winter traction #3
I've only used chains on the loader style tires on my PT1445 like Ponytug's. They make a major difference in being able to have traction on hillsides. Never used in snow myself.
MossRoad might have specific experience from using his PT425 that might be helpful. Tend to think snow traction on turf tires would need some kind of chains.
/ PT425 winter traction #4
I have turfs on my pt425. On the asphalt driveway I have no problems. Get off on a side-hill and you'll crab your way downhill. No getting around it. IF I had to plow on hills, I'd get chains for the winter and be done with it. But we are on tabletop flat ground, so no issues for me.
That being said, this weekend was 12" of wet, heavy snow on unfrozen ground. We call it 'heart attack snow', because it's so wet and heavy.
So the snow stuck pretty hard. Any attempt to push at an angle resulted in failure, as the machine is just too light to overcome the heavy slush and would drive off to the side VS pushing. So I had to go at it directly head on and push off to the sides in a herringbone pattern. No big deal.
/ PT425 winter traction #5
I have a pt 422 I use for most of my snow plowing and I have turf tires on it. Most of the time it works fine , my driveway is gravel and has some hilly areas on it. It does good if snow is not too deep and I plow downhill the first pass and then going back up I only take about half plow width usually no problem. I might add my plow is a pt plow for the 422 and 425 but I had a friend weld 9 inch extensions onto each side so it is now 6 foot 6 inches wide instead of 5 foot . If snow is deep and tractor bottoms out no tire tread or even chains is not going to help much
/ PT425 winter traction #6
We could alway switch to the straight edge bucket in a pinch and dig our ways out if necessary. I had ONE winter where I had to do that. There just wasn't anywhere else to pile the snow, even with the plow pushing it up 6'. Had to dig out a snow storage yard in the backyard and shuttle the snow back there for a couple months.
Yesterday was the first time that it was necessary to plow snow in 2 years.
/ PT425 winter traction #8
It took me a while to believe it, but turf tires, in general, have more traction in snow (over a driveway) than lugged ag R1 or industrial r4 tires. It’s the summation of all the tread edges.
At some point in deep packed snow, I suspect lugged tires start to win again.
In general: weight = traction. Weight is the only thing that increases friction between the tire and the ground so you don’t spin (on a solid surface).
On a surface material that “peels” out or is “paddled away” from underneath the tread (mud and deep snow) when subjected to force, that calculation gets trickier. You then have to either 1) “dig” through the material to find solid ground with (static) friction, or 2) float on it and distribute the force over a larger area of surface that doesn’t peel way, or 3) paddle the material behind you away with enough force that there’s an equal and opposite reaction propelling you forward. 2 & 3 are very tricky. Conditions, weight, power input and most importantly the tension of surface material all have to be balanced in unison.
(I use the term paddle to represent the horizontal force of “dug in” lugs, versus the vertical forces of friction between the tires and their surface)
That’s my 2 cents….given for free!
/ PT425 winter traction #9
I agree with Coby that turfs are better on driveway if snow is not deep but in deep snow I think R-1's have a slight advantage. I have turfs on my power trac and do not have problems with traction very often.
/ PT425 winter traction #10
Back in the 80's I had a friend that had a monster mud truck with 44" tires. He slowly drove it way up on a huge snow pile and everyone was impressed. Flotation.
When he floored it to get down, he immediately buried all 4 tires down to the frame in about 2 seconds. Paddled.
The general consensus back then was get the tallest, skinniest snow tires you could get so that you'd have more weight concentrated on a smaller patch and get you down to pavement VS wider tires that would float you up over the snow and eventually paddle down so far they could not move forward and just dig deeper.
The advantage of a bucket or plow on FEL arms on the front of a tractor is that it really doesn't matter much what kind of tire you have as long as you can lift the material off to the side and dump higher than the surrounding snow. You don't have to plow it at an angle, where traction is important. You can wishbone it all the way down the drive.
Sure it takes longer, but you get the job done VS getting stuck.
What is the proper tire pressure supposed to be (425)? To say the manual is lacking is an understatement. Also, since there is little to no chatter on the www for the EH72 engine, does anyone know the basic settings for the carb? Mine is, well, fine but probably could be a bit richer.
Thanks,
Jon
/ PT425 winter traction #12
When I had a gravel driveway I found the bar tires worked better than the ag tires. Just for kicks I used my 14 hp walk behind leaf blower yesterday on the asphalt driveway. It actually worked pretty well and the driveway was completely cleared when I was done.
/ PT425 winter traction #13
Thanks,
Jon
No one knows.
I usually run around 10psi. But one of my tires leaks now, so that one gets 25 hoping I finish before it goes flat. :ROFLMAO:
I've taken to tubing any of my tires if they start losing air on a regular basis.
And I noticed my 24 year old tires are getting a bit cracked, so may be time for another set to last until my impeding death (at a date to be determined later, much later, if I'm lucky).
/ PT425 winter traction #14
What has worked well for me to clear snow of any kind with either small or large bucket:
  1. two of my wheels (turf tires) are filled with RimGuard. They are on the front in the winter, and on the rear in the summer.
  2. My PT-1430 has Draft functionality. Seems to make a noticeable difference when dialed in.
I also have a rounded cutting edge: https://www.tractorbynet.com/forums...e-attachments-improvements.99668/post-4358521 .
Hope this helps!
/ PT425 winter traction #15
We finally got enough snow last night to plow snow. We got about 10 inches of light powder snow on top of an inch of wet snow. Got the pt 422 out and started pushing it, luckily it was light snow . I plowed my driveway and parking area and a road to my shed up the hill with no traction problems (turf tires) . I don't think ag tires would have done as good but I have no way of comparing the two.
/ PT425 winter traction #16
We've had some snow recently. I decided to use my large bucket this year instead of the plow. Takes an extra pass or two down the drive, but otherwise not much different. Scrapes the asphalt nice and clean.
/ PT425 winter traction #17
I've tried a number of things over the years for snow:
Tire chains work great. Relatively cheap and easy to install, but a bit rough on paved surfaces.
I really like the Carlisle All Trail tires instead of the standard turf tread tires. They give much better traction in mud and snow but are still easy on turf. Here is a picture of them.
The best option I have found for snow work is narrower and taller tires with an ATV style tread pattern. I am using Carlise AT 489 tires size 25x8.00-12 on 12 x 4 rims. I bought the tires and rims at fleet farm. I could not find any rims with a lug hole small enough for the lug bolts on a power trac. I ended up buying longer lug bolts and drilled out the thread of larger tapered lug nuts to mount the rims to the wheel hub. You can kind of see the lug bolts/lug nuts in the picture.
/ PT425 winter traction #18
I've been using mine to plow my 1/4 mile stone gravel drive which has some steep parts and as Moss mentioned it's the crabbing that gets you.....once you angle the blade to shed the snow to the side it changes the axis of gravity on a center articulated machine so the back end wants to go one way and the front end wants to go another way.....I've got AG tires and I put chains on the rear tires which pretty much minimizes the crabbing.....the tall boys differ from the low boys in that I've got steel fenders over each wheel and there is only enough clearance between the fender and the tire to put chains on the rear wheels....chains won't fit on the front tires.......my model also has the backhoe mounted on the rear so that may give added weight to help with traction......with a regular snow it handles 12" without a problem, wet heavy snow 8" but I'll struggle with the 20" drops that happen every now and then
/ PT425 winter traction #19
I made a set of chains from two sets and had the cross chains every other link. Put them on the front and it was a tank up to 2 feet of snow with the blade. Since then I had it paved and now use a poly cutting edge with out feet on the you don’t need chains.
I’m looking at the pic above the tires are on backwards……….. jim
/ PT425 winter traction #20
Good eyes. Only the back tires are on backwards.
Reversing the tread pattern may or may not add traction while back dragging, but it absolutely provides a mild annoyance to a buddy of mine.
Has become something of a running joke: Perfect getaway vehicle, he cant tell if I am coming or going. He has threatened to reverse the hydraulic lines to match the tread pattern. Etc.
2003 FORD F-750 SUPER DUTY(INOPERABLE) (A67714)
2003 FORD F-750...
PORTA POTTY (A67714)
Unused 2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2021 HLA...
Unused 2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
Unused 2022 HLA...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
CULVERTS / PIPE STAND (A68842)
CULVERTS / PIPE...
