DIY Snowcat build
/ DIY Snowcat build
Finished hydraulic six way blade. Tilt function to improve Nordic skiing surfaces to flat.
Six way snowcat blade.
/ DIY Snowcat build
First snow at home, careful test of blade on our lawn.
/ DIY Snowcat build #25
Nice job. That is a lot of work.
But it proves, break something down to it's parts and solve for each thing. The combine it all back together.
I need to buy a snow cat one of these days.
/ DIY Snowcat build
What? no defroster for the windshield?
Richard
Radiator now diverted to cab for heat. Has a diesel heater, too. But this was start and go before snow melted;)
/ DIY Snowcat build
Slow to non-existent winter, but recently had success grooming for Nordic skiing. Built a six way hydraulic blade and groomer this fall.
/ DIY Snowcat build #30
Did you just weld essentially a cover over an axle carrier with spider gears in it to make the dif for this? Could it really be that easy? Is it filled with oil or grease or anything?
/ DIY Snowcat build
Chevy diff from 1 ton vehicle. Used sprocket as ring gear. Made a cover for the spider gears out of steel. Filled with grease. Done.
Google "chain drive differential" for other examples.
Works reasonably well but not as good as purpose built planetary diff from a real snowcat like Thiokol, etc. When you brake one side, the other side spins at double speed which makes for lower torque transfer and kinda jerky steering. But for a "budget" snowcat build it works well enough.
/ DIY Snowcat build #33
I love the sound of that Yamaha engine. It sounds like a gas version of a Detroit diesel!
2022 LIUGONG CLG922E EXCAVATOR (A63569)
2022 LIUGONG...
John Deere Loader Frames (A63116)
John Deere Loader...
2007 John Deere X540 Lawn Mower (A63116)
2007 John Deere...
2018 DODGE 2500 RAM (A63569)
2018 DODGE 2500...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
2014 J&M 375ST Seed Tender (A63116)
2014 J&M 375ST...
