DK Hydraulic filter leak
/ DK Hydraulic filter leak #1
Markyyg
Kitties DK 4710se
I just did my 50 hour service in the hydraulic filter. The yellow one inboard of the fuel tank seems to be leaking. I tightened it up as much as I can but I didn’t notice a large O-ring on the canister. Was wondering if this is normal
/ DK Hydraulic filter leak #2
The Kubota filters that I am familiar with all had a gasket on the filter.
I would call your dealer to confirm, but I would be very surprised if the new filter wasn't supposed to have a gasket.
/ DK Hydraulic filter leak #3
Just because you didn’t notice a gasket doesn’t mean there actually wasn’t one. You need to undo and verify before you do anything else. It’s possible that you’ve simply kinked the gasket by over tightening it. My habit is to always hand tighten a canister filter, and then turn the filter in reverse ever-so-slightly.
Let us know what you find
Great information guys. Thank you very much. Appreciate your help.
/ DK Hydraulic filter leak #5
The other possibility?…..is that you’ve doubled up the gaskets. The old one remained on and then you added the new filter…with its gasket. Have a good look before you do anything else 🤞
ps…your admission that you don’t remember seeing the gasket means that you’ve committed the ultimate SIN, “forgot to put new oil on the gasket”. This lets the gasket slide along the block with the filter, preventing it from bunching up
/ DK Hydraulic filter leak #6
Great picture GM I think it’s time for me to pull my filter back off and check and make sure it doesn’t have a couple of stray gaskets on it. Thanks again for your help guys. I appreciate it.
/ DK Hydraulic filter leak #9
I ALWAYS pre lube the filter gaskets….nit doing so can cause leaks
Exactly my thoughts… only thing I’ll add: I use clean motor oil on the gasket as a lubricant… fuel filter, hydraulic filter, whatever… just an old habit that works for me…
2001 International 4000 DT 466E (A60462)
2001 International...
Great Plains Harrow Rolling Spikes (A63116)
Great Plains...
2008 Ford F-550 4x4 Landscape Dump Truck with Lift Gate (A61568)
2008 Ford F-550...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
