2025 Kioti CK3520SE cel and Codes
/ 2025 Kioti CK3520SE cel and Codes #1
Mtsoxfan
Newark Vermont
Kioti 3520SEH Holland TC29D
After clearing snow, returning to barn, tractor started acting up. Had to limp back. screen showed 944 dtc 1601 f26 52 15 16 f31 136 f17 end
Can anyone shed some light on this issue? Dealer is backed up a few days.
/ 2025 Kioti CK3520SE cel and Codes #2
Dunno the codes, but the easiest thing to do is get under it and look for a snagged wire/bundle, packed snow or stick where its not suppose to be..
But just looking around, the F31 and F17 codes relate to the DPF, and the rest are different sensors and switches. So most likely you pulled a wiring harness connector or got snow/water in somewhere..?
Thank you, I'll snoop around
/ 2025 Kioti CK3520SE cel and Codes #4
Did it throw all those codes at once? I have only had water in fuel codes on my CK3510. Turned out there was some pond scum in the fuel bowl. It ran fine, but if I was bush hogging hard and stopped to answer the call of nature it would go into limp mode occasionally.
I'm sure if you called any reputable Kioti dealer service department they would tell you what the codes mean and common solutions. I bought mine used from Larry Stovesand Equipment in the Nashville Tennessee area. They are nothing but helpful when I call in with a question. If I ran into a code I couldn't find on a quick internet search with my phone, I would call them from the tractor to see if I needed to limp to the shop. Limping to the shop is bad for me since at the top of a steep hill.
