Hard to imagine that a 4 wet disc brake system could possibly be so useless and ineffective. But it is. Mowing for 4 hours with that brake set pretty removes any doubt as to how effective those brakes are.It is a wet disc brake system which has 4 discs total. Think of it as a motorcycle clutch setup. It is immersed in the transmission fluid. While it can be worn out, it would take a long time for it do this. Tractor currently has 2,500+ hours on it, and I'd like to say I've probably "rode" the brakes well over 50 hours in it's lifetime. Brakes still work fine, and I've yet to adjust them because it holds just fine on inclines with load. Besides anytime I am on an incline, I drop the loader on edge to dig in a little bit if it does decide to move.
I still remember when I first got my BX back in 2002, I accidentally mowed the entire lawn (4 hours) with the brake engaged. Felt dumb.
I did not just hit the wrong pedal I cleared snow for a bit then noticed the drag. Just wondering if I might have caused some damage and should change the fluid ? A place for another switch.... that would kill the motor if you tried to move with the brake locked ?Mine will begin to stall the engine if I try to move it in high range, and in low range it is really obvious that there is a very large drag happening. The brake will easily hold it on a 15-20 degree hill.
Never had a problem hitting the wrong pedal.
Bruce
