Flashing dash lights
/ Flashing dash lights #1
D&D
KIoti, JD, Kubota
My DK5310 would not start this morning, 20 F. Dash lights on, turn key, nothing. Went and got a jumppack, dash lights on, turn key and very light on the dash is now flashing. Tested battery and it has a bad cell (or two?). Came back with new battery, dash lights on, turn key and it starts.
From reading, all dash lights flashing is a critical systems failure. DTC codes will hopefully lead you to which critical system is dead 🤷‍♂️
Just a heads up post because I’ve never seen this before on any brand.
/ Flashing dash lights #2
I read a thread several months ago about low or bad batteries frying ECM's due to low voltage / high amperage through the circuit board.
It was concerning enough that I swapped out my 10 year old battery that had been cranking slower than usual.
Hope you get it straightened out.
New battery resolved my issue. Luckily, every light flashing was just a pulse quickener.
Does look like there should be a warning attached to not use higher amperage boost for jump starts.
/ Flashing dash lights #4
Haha, pulse quickener! That would get my pulse up there too. Glad you're back in business.
KUBOTA FRT LOADER ATTACHMENT (A62130)
KUBOTA FRT LOADER...
Snap-On Southern Thunder Edition 24-drawer tool box (A63118)
Snap-On Southern...
2016 Big Tex 50LA Double Axle Utility Trailer (A61165)
2016 Big Tex 50LA...
Gehl RS5-19 (A62177)
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2003 Ford F-250 Pickup Truck (A61568)
2003 Ford F-250...
