Hydraulic Pump - TC55DA EHSS
/ Hydraulic Pump - TC55DA EHSS #1
99k1500
Member
Oklahoma
TC55da
I am going to start this as a new thread with more details, as I have a feeling more people with these tractors or pumps are going to need details.
Originally I piggy backed on another thread - But this is now about more than just a leak.
www.tractorbynet.com/forums/threads/tc55da-hydraulic-leak.138470/
The pump on these units is no longer in production and currently there is not a substitute.
Pump part number SBA340451161
This pump was used on the EHSS models of
Case / New Holland Tractor Boomer 4055 / Boomer 4060 / DX48SSS / DX55 / DX55EHSS / DX55SSS / DX60 / FARMALL 55 / FARMALL 60 / T2410 / T2420 / T2520 / TC48DA / TC55DA
I "believe" it was made by kayaba as an OEM part
In my case the case housing cracked during a cold weather startup. I believe that is the case for another member in PA.
I have a couple of people working on a remanufactured or aftermarket pump, but they don't seem to be available. There is hope that a company is developing one or at least that was referenced in the original thread.
This is a dual pump / tandem. I am in the process of working with a machine shop to try do duplicate the front end of the housing.
Here is a picture of the crack at the front of the housing as well as a screenshot of a slow motion video I took on startup - showing the fluid rushing out of the crack.
Here is a stolen image from the internet ( stock photo ) The crack is under the companies logo on the portion of the housing.
/ Hydraulic Pump - TC55DA EHSS #3
Why does it cracked with cold start up? What does each section of the pump do? Could it just be made into a single pump?
/ Hydraulic Pump - TC55DA EHSS #4
Typically pump housings cracking is from over pressure or pressure spikes. Cold oil could have or may have caused an over pressure condition.
99k
What is the mounting pilot diameter, drive shaft dimensions, mtg bolt pattern, displacement? With this information you might be able to find a pump that will bolt up but most likely the ports will be in different locations and possibly different sizes.
It is also possible that an OEM pump manufacturer made a custom shaft so you were forced to buy from New Holland.
FWIW,
I have no specs on the output of this device, but since these tractors are EHSS, I am unwilling to mess with the specs too much.
Currently working on this is:
NewHolland of Tulsa
TractorPartsASAP ( all states ag parts ) says they do not have an alternative - they looped in Precision Fluid Power out of OKC - They say they are working on alternative pumps / adapters
Contacting PeriParts out of NJ stated there is no known replacement.
I have contacted the TWO entities that say online they have a pump... Both indicate it is out of stock - one of these came from researching on TractorHouse
( from the other thread ) User cj7jeep187 out of PA has been working on it as he has the exact same issue last week.
I spoke with a used parts group out of central PA that told me they’re working with an aftermarket manufacturer that may actually have a reproduction version available in the next month or so. They’re going to call me when they know more and I’ll post here. I’m also looking at local fab guys/hydraulic shops that can try to repair since I’ll probably pick up a replacement anyway.
/ Hydraulic Pump - TC55DA EHSS #6
I am not sure how the EHSS interfaces with the pump but wish you the very best in finding an alternate solution.
I am not sure either, but it is not a normal clutch it is an inching pedal and an electronically controlled hydraulic shift. I do know all of the EHSS units utilize a different pump than the standard units.
EHSS (Electronic Hydraulic Shuttle Shift) transmission is a, often found in New Holland tractors, that allows operators to change between forward and reverse gears without clutching. It uses hydraulic clutches for smooth, fast directional changes, improving efficiency in tasks like loader work. It is often distinguished from fully manual or fully hydrostatic systems.
/ Hydraulic Pump - TC55DA EHSS #8
Does the pump have a manufacturers model & serial plate on it? Even though it is likely a special for New Holland, the oe manufacturer's number may provide some information to help to reverse engineer a solution . If it is KYB, I am attaching a KYB hydraulics catalog link that I found.
https://www.kyb.co.jp/english/media/hydraulics_products_guide_en.pdf
There is also a phone number on the back page in case you have not contacted KYB yet.
Good Luck
Good Luck
Thank you! It is a lead.... I had found that same document.... But just got the pump off today. I have reached out to AZTEC
*The original pump is obsolete and no longer supported from Kayaba and CNH. This is a custom-built aftermarket replacement that matches the performance but may be larger than the original pump.
/ Hydraulic Pump - TC55DA EHSS #11
@99k1500 sorry to hear about your troubles. This pump is a challenging one to find information on.
It fits New Holland: Boomer 1055, Boomer 4060, T2410, T2420, TC48DA, TC55DA. Case IH DX48, DX55, DX60, Farmall 55, Farmall 60.
Below is a link to salvage NH units.
Below is a link to salvage CIH units.
The full number is KPN05-35-17CE and your right about it being a KYB number.
KYB USA might be able to help you.
Please keep us all posted as your solution will most likely help others.
AztecHydraulics Replacement Pumps indicates they are 4-6 months out on the pump.
KYB-KPN05-35-17CE
I am also interested on any rebuild information someone has. If I am going to try to get it to a machine shop, I might as well replace what I can while it is apart.
Ok guys Aztec came back today and said it was ready for purchase - they though a remanufactured was months out but it is ready ( really hope this is not a SCAM ) A little over $1400 bucks shipped... No tax.
On Thu, Feb 5, 2026 at 1:27 PM Mike Saroli <mike@aztechydraulics.com> wrote:
Hello,
I have found a quicker solution for this unit see below.
KYB-KPN05-35-17CE
$1395.00 USD per p/c
1 week to ship
Non cancelable non returnable if ordered.
Let me know if you would like to move forward with this request.
Best regards,
/ Hydraulic Pump - TC55DA EHSS #14
Very interested in how this turns out. I've been using Amsoil full synthetic 5w-30 hydraulic transmission fluid in my NH, but coldest been out in was about 15 degrees F. I hope all this goes well for the both of you.
Latest update is that Aztec called today to say the supplier is indicating mounting issues for the TC55DA. This is disappointing, but kudos to Aztec for due diligence.... Evidently the way this pump mounts creates clearance issues on this tractor...
More later.
Current update from the aftermarket manufacturer: Based on some measurements I sent them they are working on machining down their pump. They think they can make it work. They are getting in touch with a a local Tractor for more measurements and to verify fitment. I hope to have a pump in about three weeks.
/ Hydraulic Pump - TC55DA EHSS #17
That's what I was hoping that they could machine it down to fit.
72in. Fine High Side Skeleton Skid Steer Bucket (A65640)
72in. Fine High...
12ft. 28 Gauge R Panels (A65640)
12ft. 28 Gauge R...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A64556)
2016 Volvo VNL T/A...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
