Shrew_Gardens
- Joined
- Oct 7, 2023
- Messages
- 58
- Tractor
- BCS 749
I saw what you did there.40 inches, that is a big ash log
Depends on the trailer, but most of them should be able to support 1/3-1/2 the trailer load I would think. Seen them hold up to just about anything that will fit. They can still get ding up though.Does anyone know how tough the drive over fenders are
That's interesting, as I've seen others do it with the arch hinged at the middle of the trailer, such that the arch swings from tailgate to front railing, as it lifts the log. Never seen one mounted at the rear, before!Another method involves mounting a loading arch on the back of the trailer. The arch can be made to be easily removable, if desired.
The advantage of a midmount is that you can often the log loaded in one "swing". The disadvantage is that it takes some extra figuring and probably a lot taller arch to get the log up over the tailgate.That's interesting, as I've seen others do it with the arch hinged at the middle of the trailer, such that the arch swings from tailgate to front railing, as it lifts the log. Never seen one mounted at the rear, before!
Typically, the parbuckling ramps are designed in such as manner as to not put any load on the fenders, since most trailers don;t have fenders intended to handle that sort of load.Does anyone know how tough the drive over fenders are, specifically would they be likely to hold up with a larger log rolling over them from the side when loading with a parbuckle? There is a Load Trail 12k trailer with them nearby that looks nice.
A log splitter or small utility trailer behind your CUT is a great aide in learning how to back a trailer, as the tractor offers better visibility. That's how I learned as a kid, anyway, and I can back a 20' trailer thru a slalom course at speed.Now I need to practice backing this thing up.
I went with a 7x16 deck over with drop sides
7 feet is uncommon? You mean just for deck-overs, or trailers in general?That's a strange size, 7' wide deck over.
Yes. I always try to stay on any chipped or damaged paint, either with rattle can or a small can and brush. Anything beats rust!Anyone know whether it’s worth using a rattle can of rust-oleum on those spots where the finish is flaking?
Not sure if I have followed this correctly, but if you intend to parbuckle a 7,500lb log I hope you video it for us all to see! (Maybe you are sectioning it first before loading?)The heaviest logs I've dragged with that winch are 7500#, with the primary limitation being anything heavier just drags my truck and trailer backwards, while the log goes nowhere.Of course I use wheel chocks, but I've dragged the whole rig backwards right over wheel chocks.
I have not figured out the similar function on my f350, assuming it exists.My personal issue when backing a trailer is going straight back. The trailer is going say a tiny bit left but I don’t identify quick enough. What kind of truck do you have? Newer F150’s have a trailer backup know, I’ve never bothered to set it up on mine. Good luck with the new trailer and post up a picture of it.
The trailer is a ‘24 Iron Bull 15k 7x16 dump with drop sides.
That is a great firewood setup.A log splitter or small utility trailer behind your CUT is a great aide in learning how to back a trailer, as the tractor offers better visibility. That's how I learned as a kid, anyway, and I can back a 20' trailer thru a slalom course at speed.
When you get good enough at regular trailers, then you can mix it up with a steerable wagon, which reverses everything, again! Jacknifing this one onto my patio every second weekend is like threading a needle.
View attachment 4889056 View attachment 4889058 View attachment 4889057 View attachment 4889059
