Hello - Kubota 2011 L5740 purchaser
/ Hello - Kubota 2011 L5740 purchaser #1
mgonzales08
Texas
Kubota L5740
Hello, i'm in the process of buying a 5740, 2011.
New to tractors, but will need for the fence, pasture, hay, and land work in the future.
Here to lurk and learn what I can about everything. Went pre def to avoid the long term maint costs, 2011, 1300 hours. Good condition, has 3rd function and 2 rear remotes, R4. Tried to get a decent size for round bales, with some decent longterm reliability.
/ Hello - Kubota 2011 L5740 purchaser #2
That's a nice pre emissions machine - I'm sure you'll be very happy with it.
It would be pre dpf though, not def on a machine of that size.
/ Hello - Kubota 2011 L5740 purchaser #3
That is a nice tractor.
What is the asking price.
That is low hours and should serve you well.
/ Hello - Kubota 2011 L5740 purchaser #4
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
/ Hello - Kubota 2011 L5740 purchaser #5
and enjoy the forum!
/ Hello - Kubota 2011 L5740 purchaser #6
I have a 2007 L5740. Great machine. 100% trouble free the whole time I have owned it. The only problems have been totally self-inflicted, aka stuff I have broken.
/ Hello - Kubota 2011 L5740 purchaser #7
I have a 2011 L5740 with about 2500 hours on it. It's been a good tractor. The main issue I've had is front wheel bearings. I've had to change them 4 times now. Here is a thread describing my bearing problems. Overall I think you will be happy with it.
Thanks all, i'm sure there will lots of little things to get down over time, but did a good bit of research to best of my abilities, and looking forward to the work to come.
Going for quick hitch, rim guard, auger 9/12in, pallet forks, bush hog, bale spear eventually. Only bout 4 acres to take care of, but need to rework the land a bit for pastures for 2 horses, do about 1500 ft of fencing along the front side, and inner parts, and then start on some light grading and irrigation work for a barn, which my neighbor got a box blade I could probably work somethin out.
Should keep me busy a good while to say the least.
/ Hello - Kubota 2011 L5740 purchaser #10
Interesting. No problem with mine, but I probably just jinxed it. And I only have 1000hrs.
/ Hello - Kubota 2011 L5740 purchaser #13
Great tractor, I have had mine for 14 years and have almost 1000 hrs on it. It is mostly used for mowing, and snow blowing. I also have a BH92 backhoe, chipper, and also use it for other stuff.
I have had a couple of issues with it. Leaking front axle seals, easy repair which I replaced myself, and a leaking seal in the front wheel driveshaft, which required a tractor split to replace. Took it to the great dealer for that one. Apparently not an uncommon failure, and the dealer was quite familiar on how to do it, and without removing my cab.
