Quality on-board float charger?
/ Quality on-board float charger? #1
FlyFishn
Gold Member
Kubota LX2620HSD, IH 444 gas
What are some of you running for a quality on-board float charger/maintainer?
/ Quality on-board float charger? #2
I'm using primarily BatteryMINDer and PulseTech products.
Not as on-board, but still. On some batteries I have on-board desulfation units, though. Canadus and PulseTech.
/ Quality on-board float charger? #3
I have been happy with Battery Tender brand maintainers.
/ Quality on-board float charger? #4
My vote goes to the various BatteryMinder chargers. I have one with a splitter that maintains my diesel mowers off season, one for the tractor, one for the truck, and lastly...a 48v desulfator for the cart.
/ Quality on-board float charger? #5
Costco recently had their $70 5 amp battery tenders for $50 and I stocked up. Lead acid and lithium compatible. 6 or 12V
/ Quality on-board float charger? #6
Same here, got a couple 750ma maintainers and a 5A charger/maintainer sounds like the same one Quaffer mentioned. I used to swear by Schumacher but I had one fry a new battery on my bike as did the replacement one and the communication by the company was zero so no more.
/ Quality on-board float charger? #7
I've been buying NOCO Genius2D for onboard chargers, maintainer, desulfication as well.
They have many different sizes, some with multi banks, and on board ones come with eyelets vs clamps.
Well rated and haven't let me down yet. Oldest one have though is only about 2 years old?
/ Quality on-board float charger? #8
Be careful with the high voltage desulfation maintainers. The high frequency ones can be used with the battery connected to late model computerized things and not hurt a thing.
/ Quality on-board float charger? #9
something I new nothing about.
A little on line research shows the NOCO Genius2D that we are using seem to put out pulses 6x / hr in the 13.2V to 14.9V range to desulfate the plates. Also says the charger doesn't float charge the battery but shuts off completely when voltage target reached.
Seems like this is safe range not near the 60v unsafe range.
Does this seem correct or should I get the boys to stop using them?
/ Quality on-board float charger? #10
As I recall I measured well over 20 volts when my NOCO spiked.
And I don't think that 13.3 to 14.9 volts would do anything to get rid of sulfation. If so, just driving my late model cars would automatically desulfate my batteries since that's normal charging voltages for them.
This one looks similar to what I am thinking:
However, I am not quite following the product line. This charger/maintainer/desulfator is less expensive than a stand alone monitor/desulfator. That doesn't make a whole lot of sense to me.
At the end of the day I want something I can plug in that is going to reliably maintain the tractor battery. If these have the ability to prolong/extend the battery life - even better.
My intent is to install it on the tractor. I don't need to move it. We have other high powered chargers around if we need a "charge" or "start", and other batteries sitting have maintainers. So there really isn't a need for this one to "move" once installed.
/ Quality on-board float charger? #12
I've got a few of these Noco maintainers. I've never used the desulfator mode. I have no complaints and it looks like Nocos are not quite as much money.
/ Quality on-board float charger? #13
I've been using a solar charger and have been very pleased with them.
Voltset 12V Solar Battery Charger - 20W Waterproof Solar Panel Kit with Smart MPPT Controller​
/ Quality on-board float charger? #14
I have quite a few late model BatteryMINDers that were on sale for about $20, and are in use 24/7 on vehicles that are seldom driven. Some of my 'MINDers are around 30 years old by now.
And yes, my Canadus desulfators were over $200 a piece, but they sure work well.
i went ahead and ordered that Battery Minder 1215C unit. I did some research on them this evening and of the units they offer I think that covers all the bases I need. It looks like all the maintainers are 1.5 amps, but if it is plugged in all the time that should be fine. It isn't intended to be a "quick charge" and we have other chargers for that anyway. The goal with this set up is to not need to "charge" as it will be already.
/ Quality on-board float charger? #16
That's good. The lower the fluctuations in charge are, the longer the battery will last. They only have so many cycles in them, and the shallower those cycles are, the better.
/ Quality on-board float charger? #17
I've used an under hood permanent mount charger, with 110v cord to plug into out the front of the vehicle. Schumacher SE-1-12S. A more up to date model is the Schumacher SC1300.
They have no other features that I'm concerned with other than to plug in and maintain. One vehicle is used for short 1,2,10 mile trips and needs additional charge to stay topped off. Others sit for periods of time and need maintenence there. No complaints. Plug it in and leave it.
/ Quality on-board float charger? #18
The BatteryMINDer 1215c is a good on-board maintainer. It desulfates and is temperature compensated, so it will maintain the battery at full charge in varying ambient temperatures (some charger/maintainers do not adjust the charging and float voltages for various temperatures, which is necessary to charge the battery fully.) They can be safely left connected to the battery and plugged in long-term. They are rated IP 63 - "Dust tight: No ingress of dust; complete protection against contact (dust tight). Protection from water falling as a spray at any angle up to 60° from the vertical shall have no harmful effect." So you don't want to hit them with a hose or pressure washer, but should be fine if they get splashed.
The Noco 2d charger is also designed for on-board installation as a low amperage maintainer. Desulfates, temperature compensated, IP 65 rated (Dust tight, protection from water jets from any direction - so hosing it off is not a problem, but hitting it with a pressure washer - high pressure jet - is not good).
I have both, and have been happy with both models. I also have higher amperage chargers from both companies - all are excellent products.
/ Quality on-board float charger? #19
I've been using the Schumacher SC1300 on my BX2200 for about 15 years now. I routed the little pigtail out the side where the battery/grill cover is. I keep it on all the time when I'm not using the machine. I do this in lieu of a using the block heater to have a nice strong battery for cold starts.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A65053)
2018 GENIE GTH-636...
