Shrew_Gardens
- Joined
- Oct 7, 2023
- Messages
- 58
- Tractor
- BCS 749
I’m looking for a flat deck trailer, main use will be moving my appx 2 ton CUT to and from the family wood lot and also occasionally moving some select hardwood saw logs, nothing over 16’
-Deck over vs lower deck with fenders is the biggest question. I’ve considered a deck over specifically to allow loading logs over the side using a parbuckle but I wonder if it is worth the added deck height and cost?
-if I go with lower deck is it worth getting a tilt? More to break?
-Some of the trailers I’m seeing have pull out ramps, this looks more flexible for different applications but will these be much less secure when loading a tractor?
A few points:
-I’m a noob on trailers, have just rented occasionally
-I don’t anticipate frequent use (maybe 6 times a year) and I never buy anything new
-I have a 1 ton to tow
-space at home is an issue, I want the shortest trailer that will do the job
-I will probably move to a larger tractor and/or a small skidder (like a jd440) at some point so am leaning toward 12-14k
Thanks and please feel free to point me to threads that will help.
A few points:
