Building Lake Corona
/ Building Lake Corona #1,401
Nice job and video! Watching the video, it was visibly light in the rear, and probably felt even worse. I'd have been worried about dropping the stone on the pillars.
All the best, Peter
All the best, Peter
Had to go slow and make sure I had the slab above the columns. Definitely didn't want to have it fall and crack them. Placed some fast set concrete powder on top of the columns before setting it to account for the rough surface. Too cold to mix it with water today. It's solid at the moment. If it develops any play I can always lift it and mix a handful of cement for each column and reset it.
/ Building Lake Corona #1,404
Sometimes just exposing to moisture will harden it.
/ Building Lake Corona #1,406
I've been manhandled trying to move and lift big flat stones with my 60 horse Kubota tractor...they are deceptively dense and heavy.
That Case is a beast to be able to get that slab up...and then shift the weight further out on the forks and still ooomph it up.
Very impressive!
Very impressive!
I was pretty well maxed out. Still had a lot of verticle lift left but no counterweight. The tilt cylindars were close to maxed out with that slab almost 10ft out from the pins. J.
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
Deere 333E (A60462)
Deere 333E (A60462)
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
iDrive TDS-2010H...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
