Building Lake Corona
/ Building Lake Corona #1,401
Nice job and video! Watching the video, it was visibly light in the rear, and probably felt even worse. I'd have been worried about dropping the stone on the pillars.
All the best, Peter
All the best, Peter
Had to go slow and make sure I had the slab above the columns. Definitely didn't want to have it fall and crack them. Placed some fast set concrete powder on top of the columns before setting it to account for the rough surface. Too cold to mix it with water today. It's solid at the moment. If it develops any play I can always lift it and mix a handful of cement for each column and reset it.
/ Building Lake Corona #1,404
Sometimes just exposing to moisture will harden it.
/ Building Lake Corona #1,406
I've been manhandled trying to move and lift big flat stones with my 60 horse Kubota tractor...they are deceptively dense and heavy.
That Case is a beast to be able to get that slab up...and then shift the weight further out on the forks and still ooomph it up.
Very impressive!
Very impressive!
I was pretty well maxed out. Still had a lot of verticle lift left but no counterweight. The tilt cylindars were close to maxed out with that slab almost 10ft out from the pins. J.
Kubota GR2020G (A63688)
Kubota GR2020G...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
CSI SLASHER GROUND SAW (A64276)
CSI SLASHER GROUND...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2007 Peterbilt with a CAT Engine (A62679)
2007 Peterbilt...
