Farmtrac FT360DTC with Loader
/ Farmtrac FT360DTC with Loader #1
dofellows
FT360DTC by FARMTRAC
I can't find a transmission/hydraulic filter to fit my tractor. The standard parts don't fit (LG1097 or A1823132). The correct part has a larger 1.5" diameter for screw-on attachment. My part manual lists LG2359 as the filter option for an 360DTC tractor with a loader. I haven't been able to locate that part number. The filter I removed is nominal 8" long with about 4.3 inch diameter and 1.5" screw on threads for attachment. Any help would be greatly appreciated.
/ Farmtrac FT360DTC with Loader #2
My Farmtrac 360 DTC with FEL didn't take the filter that they called for either, mine took a Napa hydraulic filter # 1715, which is the correct filter for a 390 DTC pretty sure it has metric threads and they are pretty proud of them , but I bet that is the filter that you need as well.
By looking for a filter with 1.5 ID screw-on threads with 4.4 OD and a length of 8.0 inches I found part number 40007638. It also cross references to NAPA-1715 and WIX-551715. So you are spot on. The 40007638 is readily available online for reasonable amounts. I paid about $25 for one. I appreciate your help "Lineman North Florida"! I an near Live Oak myself.
My tractor has an oil fill cap just below the fuel injection pump. It is depicted in my parts manual on page 15-3 which is labeled as the Governor. My owners manual doesn't address this as part of maintenance. I hope you are familiar with this and can advise about lubricant/0il and change interval specifications.
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
