M6060/M7060 w/backhoe
/ M6060/M7060 w/backhoe #1
simmonslr
Sagle, ID
Kubota L5450
Anyone here own an M6060/M7060 with backhoe. I have access to a backhoe subframe for an M5660 and was wondering if I might be able to adapt it to an M6060 or M7060. Not finding much online or Kubota Parts. Maybe some photos would help me figure out if it's possible. Thanks.
/ M6060/M7060 w/backhoe #3
have you consulted your service dealer on that? or AI? regards
Yep. Working with one now (and AI was my first stop). He's as much in the dark as I am. Thanks for the idea though.
Even an owner or installation manual might be helpful, but don't find those either.
/ M6060/M7060 w/backhoe #6
well keep us informed. you might call K central on that, they should know, good luck
also, if you have a good dealer parts guy he should know about parts interchangeability if he's good. regards
/ M6060/M7060 w/backhoe #7
AI: Directly adapting an M5660 subframe backhoe to an M6060 or M7060 is highly unlikely due to specific frame designs
/ M6060/M7060 w/backhoe #8
M5660SU is closer to an M7040SU than an M7060, rear ends are different. I'd think it would be a lot of work to make it fit.
As with anything, with a welder and fab skills anything can fit.
/ M6060/M7060 w/backhoe #9
You may check out some aftermarket options, like Woods, or Wallenstien. Hard to know what they may share as far as drawings.
I gave up on the backhoe thought when the whole cost came to light. But, also having a Cab, it would be a pain to get out, then up on a chair to dig, then back in cab to move a bit...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
Front Tank Bracket (A64127)
Front Tank Bracket...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
iDrive TDS-2010H...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
