Steering wheel removal
/ Steering wheel removal #1
Jeff Pizzi
JD 755, JD L130
I need to remove the steering wheel from my '98 JD 755. The nut comes right off, but I can't get to wheel off the shaft. I've tried a three arm puller with penetration oil. I've tried hitting the shaft and nothing works. My biggest concern is breaking the wheel. I want to take the wheel off so I can dismantle the instrument panel. Any ideas? TIA.
/ Steering wheel removal #2
I've tried regular pullers, and a bearing puller to be kinder to the steering wheel, no luck. That was shortly after getting my new '10 M6040.
Left the nut off in hopes of the splines eventually deciding to loosen up. It's still on there, firmly as ever.
/ Steering wheel removal #3
Failed similarly on my Kubota. :(
/ Steering wheel removal #5
Can you create a dam or cup to hold the penetrating oil & give it time to seep down through the splines? I'd suggest heat, but the plastic would probably let go before the rust, in which case you could get it off but then need to source a new wheel. Depending on where you are & ambient temps, might want to hold the wheel at ambient temp & try freezing the shaft with freon if you can get near enough to spray it without freezing the wheel collar. (granted, this is probably not "eco friendly" but if you have no other way to get it off ???)
/ Steering wheel removal #6
Hitting the steering shaft with a hammer is a great way to damage bearings in the steering box.
/ Steering wheel removal #8
Unsure if this will help. My Kubota has a special tool for removing the steering wheel. Attached is a picture.
It looks like a gear puller with a circular metal plate attached to the three legs of the puller. Likely because the steering wheel is mostly plastic and deforms too much using just the three legs of the puller.
Maybe you you could modify your puller to make something similar.
/ Steering wheel removal #9
LOL @Chewwy you may want to double check your attached image. There may be some folks from Minnesota on this forum looking for medicare part d plans.
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
1981 Mack DM492S T/A Flatbed Fuel Transport Truck (A59230)
1981 Mack DM492S...
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
