WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 15,009
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Not a tractor topic, but there's such a wide range of expertise here, I figured it'd be foolish not to ask: are there any folks here real knowledgeable on foam compression, stiffness, and preloading for packing? I have some 1U chassis height rack-mount electronics devices weighing 25 to 36 lb. each, and need to prepare them for international shipment. Chassis size is the usual 17" width (19" at mounting tabs) x 1.75" high for rack mounted hardware, with depths of 16" and 24" for the two respective weights listed above.
I'm figuring 2 units per box with foam surrounds and coardboard separators, and setting the boxes onto pallets like books on a shelf. That means the weight of the product will be sitting on the foam surround, such that we need to get the density of the foam right in order to support the product weight.
If the orientation is such that the product is standing up on the face panel of the rack chassis, that's a footprint of 19" x 1.75" = 33.25 sq.in. for either product, and relative pressures of 0.75 and 1.08 psi for the two product weights.
If we need to keep foam pressure consistent between the two product types, I could set them on their sides and hit 0.84 to 0.89 psi on both products, but they'd take up more pallet space and the delicate "ears" of the rack chassis would be facing down, unless removed prior to shipping.
I'm not totally confident on choosing the right foam density for this job, but schedule and costs make it relatively important to get this right off the bat. If anyone here has experience in this type of packaging, I'd appreciate some advice, or at least confirmation of my material selection. I can do math, but I have no real experience in choosing packing foam without a lot of trial and error.
