Ford 545D shuttle shifter woes
/ Ford 545D shuttle shifter woes #1
Sonibellus
Ford 546D
Hey, all. I'm wondering if anyone has a solution for shuttle shifters that aren't the $700 OEM replacement
The issue is totally with the shifter stalk itself. It's pretty intermittent with both forward and reverse and jumps out pretty often. I had become accustomed to simply holding it in place but now that's also sporadic at best. I've had it apart and tried to reshape the metal that actually completes the circuit on the contacts, but it's not much better.
Any ideas, or do I just bite the bullet?
Thanks!
/ Ford 545D shuttle shifter woes #2
Welcome to this forum
I'm not familiar with a Ford 545D. It sounds as if you tractor has gears for reverse not hydraulic shuttle? If that correct I would be suspecting wear in gears &/or shift couplers in correlation with shifter controls.
/ Ford 545D shuttle shifter woes #3
Thanks!
Technically, it’s just a toggle switch on/off/on (plus lockout?) would take a little splicing and fabbing ….
/ Ford 545D shuttle shifter woes #4
This will work for that shifter. You may have to rewire, but that isn't difficult.
Chinese import
If it has the 8x8 transmission with lockout, you could put an extra button somewhere else to activate. Most people don't use it though
This one might be best:
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
Blue Diamond Brush Cutter (A64126)
Blue Diamond Brush...
Landhonor Mini Skid Loader (A66285)
Landhonor Mini...
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
