Yes, thank you Harry. I have a PM that says they are 1" bore Wagner brand slave cylinders. I will edit the thread from: "Hydraulic Valve ID and suggestions to Free and or rebuild" to "Slave Cylinder - suggestion to free and or rebuild"They don't look like valves to me. More like slave cylinders. I have no idea who may have made them.
Thank you Leejohn, I will give that a try tomorrow.I would take it off, take the bleed screw out. Tap piston in as far as it well go. Clean real good, sand paper what you can. Put light oil in, come back the next day. Drain the oil and hope it pulls out. If not try air pressure in the bleed hole. Put rag over the end and don't let anyone be in front of it. Do not use the hose side that might have a check valve in it.
Good evening True. I am working on a Rotheisler Kangaroo. See the following thread: https://www.tractorbynet.com/forums/threads/rotheisler-kangaroo.440805/Good idea on using grease to get them out.
Problem is a regular zirk won’t be the right thread.
What kind of machine are we working on?
May be able to cobble something up using the input fitting instead of the bleeder screw?Problem is a regular zirk won’t be the right thread.
