Glow Plug Use
/ Glow Plug Use #1
HAR
Vermont
Kubota B7300HST (1999)
Maybe this is an old topic, but I have searched, and while there is some glow plug discussion, I found nothing either serious or in depth.
When using glow plugs to preheat for cold starts, does anyone have any better information or knowledge about what is the proper/correct amount of time to preheat before trying to start a diesel engine?
The reason I ask is this. After having had my B7300 for over 23 years, I had my first cold start issue this past week. In the past, it seems, I really have not had the need to start my engine in really cold weather. However recently, we had a couple small snow storms, nothing enough to warrant clearing the yard and drive, but freezing rain was in the forecast, and following that a much colder freeze. I decided to clear up what was down and around before the rain and freezing rain made a mess, and the forecast deeper freeze turning everything into a rutted skating rink.
As it was about 15F at that time, I put everything in neutral, depressed the clutch, moved the key to preheat, and held it there for 10 seconds, basically what the manual said, and has worked in the past, but I cannot attest to what the temps were when I did those cold starts. However, this time, the engine did not fire on the first try. So, I waited about 1 minute, and repeated the process, and once again, it did not start. So, I repeated it for a third time, and the engine started. I did my clean up and put the tractor away, but I got to thinking about this, as winter here is basically just getting started. I reread my user manual, and confirmed what I had done was what was prescribed.
The next day it was much colder, 7F, and I decided to do a test. I went out and began the cold start procedure, but this time I held the key in the preheat position for 20 seconds, and it started right up. I am now wondering if the user manual is being a bit cautious with the preheat time? Or if maybe there is a more widely used or accepted thought/theory/procedure ?
BTW, Happy New Year 2026 to all!
/ Glow Plug Use #2
My tractor, which is not a kubota, turns the glo light off, when it is done. It usually takes around 30 seconds or so at the temps you are talking about, shorter if I've had it plugged in. Kubota, Yanmar and Bobcat equipment I have used do the same thing, you hold the key in position until the light goes off. Sometimes it might take 2-3 reps if it is cold and you don't have a block heater.
/ Glow Plug Use #3
My experience with older Kubota engines is that they really really like glow plugs. The B7000 with the Z650 engine I had would need a very solid 30 seconds to start on about 5ºC temps.
The D640 in my backhoe does better with less glow plug time but still likes it very much.
With this being said, it might be a good time to see if your glow plugs are in good condition. It's possible that at least one is bad, making it harder to start. Just plug the bus bar out and measure the resistance on each one. If it gives an open circuit or very high resistance, means it's bad.
/ Glow Plug Use
I understand many newer diesel applications have auto preheat setups. I know the 2017 diesel truck that I use at my nephews maple sugar operation seems to have such a setup. Insert key, turn, and wait for all lights to extinguish before it will start. But it will fire and run right away, with no hesitation.
So, this brings up another question, which I think I knew about, but really have not followed. Engine warm up...some of these times seem pretty excessive, but what do I know. I do know that diesel engines are pretty cold blooded. What do others do?
/ Glow Plug Use #6
My Kubota B21 is 24 yrs old and always has started cold - a bit noisy if below 15* and when it's this cold I get the walk behind snowblower out and do some of the pathways while the tractor warms up, (10 minutes or so). For warm up, I start it for the first minute at idle, then increase to 11-1200 RPM for 5 minutes minimum to 10 as mentioned above.
I installed flexible pan heaters on it this year 175 W on the engine oil, and 250 W on the Hyd oil pan bottom on a wifi controlled plug I turn on 30 minutes before going to the barn, These help things warm up faster. You can find these orange flexible pan heaters with adhesive on Amazon or Walmart for $10-20 each,
/ Glow Plug Use #7
I go for 20-30 seconds in idaho cold. Sometimes cycle 2 times. But this year I tested my glow plugs and only 1 of the 4 was working. I was noticing harder starts.
I replaced all 4 a few months back. Fires right up now.
Was 5°F yesterday, and only took 1 cycle of plugs
/ Glow Plug Use #9
With the Yanmar 3TNM74F in my TYM, the glow plugs activate (for 10sec) with every ignition cycle when you turn the ignition to the on position, but you can go right past it and crank the engine over immediately if you want to. Out of curiosity, I've tested it down temps in the teens (F). Definitely wont start w/out a full GP cycle when that cold. It will fire right up in the mid-low 30s w/out though. The machine stays in my unheated garage.
/ Glow Plug Use #10
JTKub - my experience with the Yanmar's they start better in cold weather or in general without needing the glow plugs.
/ Glow Plug Use #11
the warm up times in this chart are for the HST, not the engine. I don't know why it mentions the engine in the last sentence as the engine has nothing to do with it other than how long you are running it. As it says, running with cold hydraulic fluid can potentially do damage.
/ Glow Plug Use #12
I agree, that’s why I have heated silicone heat pads attached to oil pan and transmission to preheat oils prior to starting. Has really helped frigid winter operations for me.
/ Glow Plug Use #13
Yeah, my old JD750 (which was made by Yanmar) started a whole lot easier in cold weather than my Kioti. Pretty much have to use GPs anytime it's below 35-40°, with multiple cycles if it gets below freezing. I'll have to check to see if they're all good.
/ Glow Plug Use #14
X3 on the transmission / hydraulic oil warm up times. I don't follow the times Kubota has historically placed in their manuals though.
Below 15f usually 10m of warmup, otherwise maybe 5m. I have a 1500w infrared heater that I have put on the transmission case in the past for an hour or so, which heats up the oil very well.
/ Glow Plug Use #15
I have 2 silicone heat pads on the tractor own one additional on my 25 gal hydraulic powerpack unit for snowblower. All hooked into wifi outlet that I can remotely turn on a few hours prior to use. Has really helped in tractor operation during brutal cold winter operation.
/ Glow Plug Use #16
On my Kubota RTV-X the dealer told me to turn the key to where the glow plug light comes on, count to 10, then turn it to Start. It has worked well for us. The New Hollands have timers so when the glow plug light goes out, they start. Back in 2022 when it dipped to single digits I did have to cycle the TC40DA glow plugs twice.
/ Glow Plug Use #17
My Kioti and ford diesel rigs also have timed dash lights. I have to occasionally cycle both a few times if it’s biter cold out.
/ Glow Plug Use #18
I have a 1999 B7300 I bought used with 1100 hours. I have about 1850 on it now. I rarely start it in 15F or below as I always have it in the garage before true cold starts in winter time. I have started it after it sat outside between jobs on the same cold day and it started fine. I always glow mine for 5-10 seconds. After it starts when it's cold I turn the key again to the glow position sometimes (if combustion isn't yet smoothed enough to my ear) to glow the plugs again for another 5-10 seconds while its idling. That step seems to help the early combustion a bit more while reducing smoke in the garage.
I have replaced all hydraulic lines on my LA271 loader. It happened all within a year of each other after aging, drying out, developing small leaks. I now have my eyes focusing on the other lines as I have to believe I will need to address them soon. Other than that no other repairs to mention except a new seat, as it cracked too and the internal foam could get wet and then I would get wet sitting on it. I do maintain it well on or close to Kubota's schedules.
I wish it had a temp gauge instead of that whistle. I thought of putting one in, but didn't want to crack open a port on the head or rig up something as an aftermarket custom set up. I just make sure I have a good thermostat and coolant at all times. I added bright LED lights to the roll bar with clamps. One light aimed frontwards, one aimed backwards.
I have a 54 inch deck and bagger system which mows grass fine but the deck stinks at picking up some leaves (if they were wet at some point) as the 3 blades being shorter than usual don't create enough lift/suction. But I get by on that by using my leaf blower to loosen the few areas like that, then mow over the leaves again in those areas.
/ Glow Plug Use #19
GS - Welcome to TBN and nice first post! Sounds like you have a good handle on maintaining your B7300.
You will find a lot of good reading material on here, and also note the highlighted model link - it takes you to a page about your model.
/ Glow Plug Use #20
Kubota may or may not have changed how their glow plugs work but what I have found on my BX2680, RTVX1100 and ZD1211 is if you install a digital voltmeter, you can see when the Glow Plugs reach their maximum heat level. When you hold the key in the glow plug position, note the voltage. When you see a slight increase (as little as one tenth of a volt) the glow plugs have reached their maximum heat. At this point go ahead and start the tractor. Works every time on my machines regardless of the temperature. I purchase marine grade USB chargers/voltmeters from Amazon, However I never use the USB function when I use my equipment.
2006 Freightliner Auger Truck (A63689)
2006 Freightliner...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2019 Westinghouse WSTBT1503 Wireless Speaker (A61574)
2019 Westinghouse...
2007 DRAGON  130BBL VACUUM TRAILER (A65643)
2007 DRAGON...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
