/ Your last generator Maintenance Run
I looked at it a little bit this morning. Checked the oil and the status light says ready to run etc. Yes, we have 2 heat pumps for heating/cooling. I did notice a small Generac box next to the heat pump disconnects, so there must be some integrated power management for those.
I'll pull out the manuals and start reading up on it.
Somebody Else ^, that reads Manuals ! I keep getting told I'm risking my Man Card, by doing that :oops:.
I'd expect good documentation from Generac, but as you may know by now.... grs is one of Those Guys - that probably has forgotten more about Generacs, than many people get to know.....
Concentrated in Spring and Fall, in a past job I was away from home in blocks of close to a month at a time. Away from Home; definitely highlights the advantage of an Auto-Start generator system !
Rgds, D.
/ Your last generator Maintenance Run #7,882
That’s a pretty accurate list there. As to spare parts, honestly very hard to say. There are so many different things that could fail between the generator and the switch. I carry hundreds of small parts on my service rig. But I agree batteries are the thing that I find mostly. And when a battery fails, it might have tested great a few months previously. I’ve had the same brand battery last for 10 years or 2 years. No idea why.
"I’ve had the same brand battery last for 10 years or 2 years. No idea why." Great statement here - I've had exact same thing and have no clue why either!!
/ Your last generator Maintenance Run #7,883
Got a call from the new owner of a house that I used to do the generator service. He said it hasn’t worked since they’ve been there. So I grabbed my stuff, oil, and a service kit. Probably needs a battery.
Got there, no lights on at all on the control panel. Older beige generac, 13,000kw, propane. Pulled the fuse, that was good. Pulled the battery, swollen on one side, from 2018. Don’t even register on my midtronics tester. No voltage at cables, maybe maintenance charger went bad?
Got a new battery from Napa, hooked it up and it came to life. 5 times cranking and a little thumb over the carb hole and it fired up.
Got the oil warm enough to drain. 25 degrees outside, wind blowing like crazy, on a golf course. Oil was leaking from oil filter, was loose. Not sure how that happened. I tighten them pretty tight. Last time it was done was 2021.
New oil, filter, air filter, plugs. Cleaned out the cabinet. Set exercise time and let that run. Charger was putting out 13.2 after a couple minutes with the new battery.
Good to go.
/ Your last generator Maintenance Run #7,884
I don’t like the older units battery charge system, much too complicated.
/ Your last generator Maintenance Run #7,885
It’s nice to hear new and improved is more than marketing…
Good to go.
Nice save.... was low on TLC, now addressed (y).
Rgds, D.
I was having a similar conversation today, about the charge-controllers on modern laptops (being better).
Windoze on the other hand..... 'nuff said, as I need to keep this G-rated on here !
Rgds, D.
/ Your last generator Maintenance Run #7,888
my understanding is that older chargers would cook the water out over time trying to maintain preset voltage.
modern smart chargers should go into a maintenance mode with desulphation that is supposed
to increase life of battery by reducing internal plate deposits.
nothing like the annoying buzz of a ferro-resonant charger
better chargers and lithium batteries have really upped our game.
is any generator builder offering lithium battery as an upgrade?
though realistically it's only a starting battery, no need for deep cycle.
not sure what a long lasting starting battery is like, perhaps a HD lithium
no sense in having a more expensive longer lasting battery if the charger isn't suited for it.
/ Your last generator Maintenance Run #7,889
I have a North Star 5500 belt driven generator that suddenly stopped generating power.
The capacitor failed & I don’t understand the specifications printed on it.
I’ve found one that is very similar in specification but not sure if it is compatible.
An explanation of specs would be appreciated.
Thank you
90cummins
Happy New Year!
/ Your last generator Maintenance Run #7,890
looks the same, does the connector look the same?
25 uF at 500v +/-5% is the important numbers.
The connections are what we can't see in your photo.
20800 (A56859)
20800 (A56859)
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
204549 (A52707)
204549 (A52707)
2014 Acura MDX SUV (A59231)
2014 Acura MDX SUV...
