2014 G3038 clutch safety switch.
/ 2014 G3038 clutch safety switch. #1
okielsman
Holdenville, OK
LS G3038 2wd
Where can I buy this safety switch. Or can I bypass the switch. Thanks.
/ 2014 G3038 clutch safety switch. #2
You can buy from any LS or New Holland dealer. Part number is 40007114. Put MT in front of the number for NH. If there are no dealers near you, just order it from Messick's. Sometimes they just need to be adjusted like I had to do on mine. You can bypass it if you want, but if anyone has an accident it's your responsibility. There is still a neutral switch on the F-N-R shuttle shift lever unless it has already been bypassed.
Not the same switch. Mine has a 6-8 inch 2 wire lead with a white connector.
/ 2014 G3038 clutch safety switch. #4
The original switch with wires attached was part # 40227965 used from 2010 thru 2013. In 2014 it was superseded by 40007114 which has no wires. If the original 40227965 is not available, 40007114 replaces it. Cut the wires and connector off the old switch and attach them to the terminals on the new switch.
New Holland Switch Assembly Part # MT40007114​
Part #: MT40007114
Replaces: MT40227965
Part #: MT40007114
Thank you for the information.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
Massey Ferguson 35 Special (A60462)
Massey Ferguson 35...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
Kivel trailer mover attachment (A61567)
Kivel trailer...
(2) 200 Gallon Saddle Tanks (A60463)
(2) 200 Gallon...
17501-FL (A56857)
17501-FL (A56857)
