PTO Coupler on auger keeps jumping off
   / PTO Coupler on auger keeps jumping off #1
Robb Webb
Kubota L3710
I have a PTO auger shaft that has the slide type coupler with balls in it that lock onto the PTO shaft. It now comes off of the shaft fairly often when digging in soft soil that should be easy. We have used it quite a bit on my sons 25 hp tractor and now on my 39 hp tractor. My bush hog shaft has a spring loaded button you push down on and when the shaft is pushed onto the pto it locks on securely.
Can you buy just a replacement coupler for a pto shaft that is the old style?
   / PTO Coupler on auger keeps jumping off #2
I haven’t seen one alone at tractor supply Robb but I hesitate to say you can’t buy one. It would have to be welded on. But I would guess; if you would allow a guess, that the reason for coming off is this. The two part pto shaft is difficult to pull apart and it’s unhooking itself from the tractor pto. Maybe clean it with WD or something until it slides effortlessly. Have a Merry New Year
   / PTO Coupler on auger keeps jumping off #3
Maugansville Ag in Maryland will get you the exact parts you need. Call them, they are experts. They will UPS the parts to you.
   / PTO Coupler on auger keeps jumping off #5
Unless you're very confident in your welding ability, take it to a
Drive Shaft shop. Most close to rural areas will work on Ag
equipment. They can/will replace the coupler and balance the
pto shaft. It's worth a few bucks to have a pro do the repair.
   / PTO Coupler on auger keeps jumping off #6
What Mike1955 said:
Juice it up with some WD40 and then work it on and off the shaft, repeatedly releasing the collar to get the balls to free up and fully lock in.
BTDT.
   / PTO Coupler on auger keeps jumping off #7
Bought one to replace a broken yoke on the bush hog.. should be able to find one to fit any shaft yoke:
Thank you. That’s just what I need. I had looked online but didn’t know what it was called.
2019 CATERPILLAR 246D3 SKID STEER (A60429)
2019 CATERPILLAR...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
Utility Cart (A59231)
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
