Blow by reroute
/ Blow by reroute #1
porkchop401
Member
Coushatta, LA
I have a 1963 Massey Fergusion 65 diesel that the crank case breather discharges in the front bolster area next to the crank pulley.
Is there any reason i couldn't reroute it to the air intake ? This machine has a oil bath air cleaner. The tractor does not smoke but has moderate blow by.
/ Blow by reroute #2
Great machine, had it's younger brother T035 for decades. why are you wanting to reroute crankcase blow by? belt contamination?
/ Blow by reroute #4
why not reroute it to rear of tractor rather than intake?
/ Blow by reroute #8
Dad had a 70d JD and had oil leaks that the dealer could not seem to stop so another dealer suggested a line from the valve cover to the air intake. The tractor ran for many years after that with no oil leaks.
When I worked for a MM dealer we took a hose from the valve cover to the air intake manifold to keep the oil leaks down. It worked very well.
Usually on a Perkins they have very little blowby and have found when they have a lot of blowby the engine needs repaired.
With that said and you may not want to spend money on repair then why not return the blowby to the air intake? Just don't use a huge hose/line to do so.
Just a warning --- a diesel engine is compression ignition and will run on oil or fuel that enters the engine thru the air intake. If the engine gets enough "fuel" it can run on that fuel and you will not be able to shut it off by normal means. This is what is called a runaway diesel. And why two stroke Detroits have an emergency shut off, which consists of a flap that closes off the air to the blower.
Unverferth 1225 Rolling Harrow (A63116)
Unverferth 1225...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
INOP/NON-RUNNING 1990 Peterbilt 378 Tandem Axle Day Cab Truck, VIN # 1XPFDE9XXLD293381 (A61165)
INOP/NON-RUNNING...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2024 SCAG SCZ61V Cheetah 60in Zero Turn Mower (A61567)
2024 SCAG SCZ61V...
