NS6010 Cab Cup Holder Insert
/ NS6010 Cab Cup Holder Insert #1
Centerfire
Intermountain West
Kioti NS6010H Cab
This seems silly and I searched every key work I can think of. Does anyone know of a cup holder insert that reduces the left hand cup holder down from 4.25"? I assume this is an issue for other Kioti cab models.
I'm probably overlooking something simple but some help would be appreciated.
/ NS6010 Cab Cup Holder Insert #2
2 ideas, get a short section of pvc pipe, slice length wise, heat and spread to size needed. HD occasionally has short sections of 3" or 4" black PVC pipe.
If you know someone with a 3d printer, have them print a reducer ring.
This is more or less what I did. I took a 5" rubber pipe couple, cut the coupler in half length wise, split it, and then removed about an inch. I put cheap adjustable cup holder from Amazon in the front and rear cup holders afterward.
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
LOOK! (A65640)
LOOK! (A65640)
2007 PETERBILT 379 6X4 TRI/AXLE DAY CAB TRUCK TRACTOR (A59914)
2007 PETERBILT 379...
