John Deere 1600 Blade engagement problem
/ John Deere 1600 Blade engagement problem #1
Tammy Quail
John Deere 1600
Need help on John Deere 1600 series 2 WAM Please. The front Blades just barely move and the wing blades do not move at all. All other hydraulic functions work such as deck lift, and forward/reverse. The lights in the side panel indicate that the deck is engaged. TIA
/ John Deere 1600 Blade engagement problem #2
Welcome to TBN
Thinking you might need to track down some hydraulic line pressures to separate a problem.
Might mean doing some plumbing work to isolate the different parts of the system and building or finding a pressure gauge.
Assume you have already changed out hyd. oil filters that are involved.
Welcome to TBN
No I haven’t changed the filters and I am going to try that first. Then thought about testing the electric solenoid valves for the blades thinks they may not be working properly.
/ John Deere 1600 Blade engagement problem #4
How many hours on the machine ?
Do you clean your radiator & screens regularly (Daily) ?
In my experience those 1600 WAM's suffer from heat-induced O-ring failure in the Mow Valve.
I'd look in there after testing with a flow meter and or pressure gauges.
Get the Service Manual if you haven't already got one.
About 3500 hours on it. Bought it used with this problem from a golf course so I’m not sure how well they have maintained it. Are the o-rings usually hard to replace or is it easier to replace the valve if that’s the issue? I don’t have a service manual yet so how do you recommend hooking the gauges up to the valve and what pressure gauge?
/ John Deere 1600 Blade engagement problem #6
Would strongly suggest getting the service tech manual as suggested.
Doubt the 0-rings are hard to replace, but that depends on your own skills.
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2018 JOHN DEERE 310L EP BACKHOE (A65053)
2018 JOHN DEERE...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
