Land Pride BP 1572 Busted weld
   / Land Pride BP 1572 Busted weld #1
Keglined
Kubota
By blade is shot the weld at the pivot point where you switch from right to left has a broken weld. This blade maybe has 2-3 hours of use. It is setting on a concrete pad and the weld has let loose. Too bad it is about 10years old maybe 15 years old. Anyone else have this happen or just me.
OOpps should be a BP 1572 blade
   / Land Pride BP 1572 Busted weld #3
By blade is shot the weld at the pivot point where you switch from right to left has a broken weld. This blade maybe has 2-3 hours of use. It is setting on a concrete pad and the weld has let loose. Too bad it is about 10years old maybe 15 years old. Anyone else have this happen or just me.View attachment 4640238View attachment 4640239
I had the same thing happen on my 5’ blade recently. It appeared to be tack welded in 3 spots. The cylinder was full of ice. That could have popped the top or I broke it when last used and put it away broken (not likely). My friend laid a bead all the way around the top. Everything else will break before that weld will, lol.
   / Land Pride BP 1572 Busted weld #4
I have a RB1572 bought in 2000. It was my only implement to maintain a mile of rough road for over 10 years. After many hours it broke in 2015. Not a broken weld though - worse.
But I was able to repair it and still use it today.
gg
   / Land Pride BP 1572 Busted weld #5
Unfortunately I don’t think LP are well made implements, just chicom junk. I was given one and used it to push snow. The blade bent without a really heavy load on it. Thought about reinforcing it, but didn’t want to waste my time. I cut the 3pt mount off and made it into a ball hitch for easy trailer jockeying. YMMV.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2011 CATERPILLAR 924H WHEEL LOADER (A60429)
2011 CATERPILLAR...
