/ Edit: clearing virgin land with BCS 1 and BCS for brush clearing and trail building
OP
Big wheels are better
Member
- Joined
- Aug 3, 2025
- Messages
- 30
- Tractor
- Craftsman 2 GT6000
All good advice, thanks!I've used my Berta flail mower on a Grillo for exactly that purpose and it's been bullet-proof. I'm not exactly sure what all that vegetation is, I've found that anything you can bend over with the weight of the flail mower and the forward drive of the 2-wheel, you can completely demolish. It might take a pass or more for the thicker things, and you might have to go slow when you're in the thick of it, but it'll get the job done.
I'm not sure what you've heard about reliability, but the only thing I've done for maintenance has been replacing flails - clearing land is pretty hard on them as you'll be finding rocks and other debris. I've saved all my old beat up flails and might try sharpening them to see how it goes, but even budgeting for 2 sets of flails per season is economical compared to larger equipment.
This is a problem. You can adjust a flail to go lower, but you'll also be striking dirt and crap more frequently, dulling the flails faster, so it's a trade-off. My cutting height is maybe an inch or two. The smaller stuff doesn't leave any obstacles, but the thicker things leave a stump behind. However you approach removing these, you'll be either letting time do its magic or using more expensive equipment - so, how many you have is your deciding factor.
In my opinion this is not an area where 2-wheel tractors shine. Especially if you've just cleared the overgrowth... I see this as a struggle. Sorry, just telling it as I see it from my experience. My 110D with diesel engine, loaded Ag tires, and wheel weights... I just can't see it pulling a ripper through land that I just cleared and not getting snagged on roots and rocks. It doesn't have enough traction. Pushing a blade would be a million times worse. Maybe your soil and terrain is more favorable, but I'd bet you hate every moment of your experience, even if it works.
Yes it would! BUT!!!...
1. I don't think they exist for BCS. (I know they do for other models but it's pretty limited application and requires synchronized PTO)
2. Yeah, I want one too! But it's not compatible with my G110D (and I don't think your BCS), and, even if they do... they are $$$$.
3. If your purpose is to move attachments around, you'll still have to lift them onto the trailer, move them around on the trailer, and then get them off again when you get where you want them. And let me tell you, these attachments can be VERY awkward to move around by hand when "free floating" on the ground. The weights, dimensions, center of gravity - it's just hard and awkward. I move around my flail mower, bush cutter, cutter bar, and stump grinder, and it's a STRUGGLE. There's no good way to do it.
For the price of one of those 4x4 trailers you might be better off finding a used ATV and trailer and use the tractor to load the implements onto the trailer the easy way, and then moving equipment with the ATV. Depends how far you need to go and how often you'll be moving implements.
Hope this helps!
For the dirt work with a 2 wheel tractor, I was thinking rotary plow. I agree, definitely not enough weight or traction for dozer blade or ripper in many conditions.
