Power went out, Suggestions for "emergency lighting?
/ Power went out, Suggestions for "emergency lighting? #11
Yep. And you can recharge batteries in your car/truck.
Assuming you have a 12v charger.
A colleague of mine once tried to run a tool charger off an inverter and somehow all the magic smoke got out. He didn't elaborate, but apparently the two devices didn't play nicely together.
/ Power went out, Suggestions for "emergency lighting? #12
I suspect that his Ram has 120 volt power ports.
I used rechargables for my GPS for a while and had a charger which plugged into the cigarette lighter. One day it got rather hot... luckily while I was in the truck.
One problem with inverters is that the adapters don't seem to fit the outlets very well. I've thpught about hardwiring mine to the battery... fused of course.
/ Power went out, Suggestions for "emergency lighting? #13
There is also the issue that many 120V chargers are not happy with cheap inverters (e.g. square wave, aka "modified sine wave"), and magic smoke tends to get emitted.
All the best, Peter
/ Power went out, Suggestions for "emergency lighting? #14
I recharge DeWalt batteries in my Ram every day.
Works flawlessly
/ Power went out, Suggestions for "emergency lighting? #15
Works flawlessly
What is the plug in your Ram rated for? The plug in mine says 150 watts which is pretty useless. Dad’s Ford is rated for 450 watts and we tried a dewalt fast charger in it and it trips the circuit. I’ve never tried a regular speed charger to see what happens.
/ Power went out, Suggestions for "emergency lighting? #16
Interestingly enough, we lost power Friday 10 - 3pm, same storm as OP. Winds were swift, but at night, they came ripping through. It moved anything not nailed down. Very surprised we didn't loose power. I was up at 245 to mitigate some damage, spent the rest of the night/early morning by the woodstove.
/ Power went out, Suggestions for "emergency lighting? #17
I don’t know, but it’s a lot. I will look. I have the big charger and 60V batteries rotating through the charger all the time. never one problem.
Best truck I ever owned.
/ Power went out, Suggestions for "emergency lighting? #18
Never owned a truck that had them, how does that work? Do you have to turn the built-in inverter on manually or does it somehow sense that something's plugged into it?
/ Power went out, Suggestions for "emergency lighting? #19
You would have to ask somebody who has it. I just have the old fashioned plug in inverter which sort of works with a cigarette lighter.
/ Power went out, Suggestions for "emergency lighting? #20
Wife found some plug-in night lights that come on at night, not motion detecting. They have a battery in them that will keep them lit for several hours when the power goes out.
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
Leyman Lift Gate (A59230)
Leyman Lift Gate...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
1995 Ford E-250 Cargo Van (A59230)
1995 Ford E-250...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
