What did you buy this week?
/ What did you buy this week? #3,371
That's what I thought 130x32= +4k sq ft.
Unfortunately the R value on foam is minimal compared with conventional batts.
That is incorrect. R value per inch is higher for foam (generally r-5 to r6 per inch) vs r-3.5ish for batt insulation. We do weatherization where I work and install many thousands of square feet of insulation every year.
/ What did you buy this week? #3,372
Yeah, but R-value per $ is low
/ What did you buy this week? #3,373
The best thing with spray foam is the sealing and draft stopping a good job does. With the closed cell there is no air or moisture migration. It works much better then the "R" value suggests.
/ What did you buy this week? #3,376
I bought a couple thousand dollars worth of parts today..
All my suppliers AND the factories are shut down from this coming Monday until January 5th.!!
I’ve had several people contact me saying they were pulling their pumps and shipping them to me..
I’d rather have the parts and not need them, than need the parts and not have them..
/ What did you buy this week? #3,377
I bought 60 sheets of plywood subfloor for $4 a board.
/ What did you buy this week? #3,379
An 8-oz tube of Lucas white lithium grease to lightly lube wedge slide surfaces and around the sides of the splitting beam on my log splitter. It appears many folks just use oil; Iron and Oak recommends grease. I will try it out and keep an eye out for gunk build-up, and adjust as needed.
/ What did you buy this week? #3,380
My Timberwolf was delivered from the factory with grease on the splitting beam.
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2000 Sterling L9513 Winch Truck (A61307)
2000 Sterling...
HEAVYEQUIPMENT TIRES (A60736)
HEAVYEQUIPMENT...
2020 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2020 GENIE...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
