/ Share Pics of People Hauling or Towing Something Wrong #23,192
/ Share Pics of People Hauling or Towing Something Wrong #23,196
I've seen them do a tailgate spread, but never from the side like that...
Pretty tricky!
And to the left side of the road. :oops:
/ Share Pics of People Hauling or Towing Something Wrong #23,198
Somebody in the cockpit probably said “what does this button do”. Then pushed it.
Leaving the driver seat with an overhead obstruction isn't something you normally worry about.
OUCH
Aviation News – Two aircrew members were killed after an aircraft’s ejection seats unintentionally activated inside a shelter at a Russian bomber aviation regiment on December 7, 2025, highlighting a rare but dangerous ground safety failure.​
The incident occurred when the two-seater aircraft was parked inside a protective structure and its ejection system unexpectedly fired, propelling the pilot and navigator into the shelter’s roof. Both sustained life-threatening injuries. The event has prompted an official investigation within the regiment and renewed scrutiny of ejection seat safety across Russia’s aviation units.
Ejection seats are designed to save aircrew by firing an explosive charge that launches the seat clear of the aircraft in emergencies. When activated on the ground, however, the bolt of force created by the system becomes hazardous, lacking sufficient clearance for a safe trajectory and exposing crew to extreme impact injuries.
Hydraulic rail grinder (A61307)
Hydraulic rail...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
Misc OKI Printer Cartridges and Image Drums (A59317)
Misc OKI Printer...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
(APPROX. 20) 4' X...
MAGNUM POWER PRODUCTS LIGHT PLANT (A60736)
MAGNUM POWER...
