What did you buy this week?
   / What did you buy this week? #3,271
Went ahead and reordered the 30 ton splitter from Ace HW this time. They had a better deal. Then went to Rural King and picked up 3X 5-gals of CAM2 AW32 hydraulic fluid for the splitter.
Log Splitter arrived at the local Ace yesterday; @770 lbs. crated. Will pick it up next weekend.
   / What did you buy this week? #3,275
I discovered a Smokey and the Bandit Trans Am almost identical to the one I wrecked as a kid.
Only option missing is the factory CB.
It has under 10,000 miles and hasn't seen sunlight in over 25 years.
Body and mechanicals are all original and matching. Tires are dry rotted. I'm assuming houses and other rubber seals etc to.
There's another guy bidding but I'm pretty sure I can top him.
Christmas a bit early?
   / What did you buy this week? #3,278
I gas up at Costco early Sat. or Sunday morning, always an open pump, never waited... it helps that I live only a mile away. And yes, it's $0.40 cheaper than the 3 gas stations that I pass by to get to Costco!!
We're dropping Costco because we don't make the 45 mile drive enough. Amish discount/grocery stores not far away are cheaper and fresher than Costco. Our gas is usually cheaper than it is in the city or Costco.
7 30 inch reels (A59228)
7 30 inch reels...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Metal Box with 32 Ratchet Straps (A57454)
Metal Box with 32...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
We Don't Call 911 Metal Sign (A57454)
We Don't Call 911...
(12) Ten Hole Steel Rims (A57454)
(12) Ten Hole...
