Tubed or tubeless. What do ya'll do?
   / Tubed or tubeless. What do ya'll do? #1
Happy in NC
South Mtns area of NC
NH TC45D
Took my front tractor wheel in yesterday to get it fixed. I had this one fixed before and they put a tube in it. Told them I wanted no tube unless there was some specific reason for doing so. The man that owns the shop just about everyone around here runs tubes.
What is advantage or disadvantage of each and what do ya'll do?
   / Tubed or tubeless. What do ya'll do? #2
I put tubes in the front tires of my BX24. I tend to overload somewhat with the loader and past threads here seemed to indicate the BX series have a problem with front tires holding air. Works for me.
Doug in SW IA
   / Tubed or tubeless. What do ya'll do? #3
On my 3560, I had one front tire that struggled to hold air. The tractor was new, when I reached out to the dealer, he recommended that they would put in a tube. I did not care for that idea, but after numerous times of the tire going flat, cleaning the rim and tire, using rim seal and changing the valve stem all with out fixing the problem, I assumed I had some defect with the rim. Installed a tube which failed soon after. I installed a new tube, so far so good.
   / Tubed or tubeless. What do ya'll do? #4
What is the disadvantage of putting a tube in a tractor tire?
   / Tubed or tubeless. What do ya'll do? #7
Within a few hours of owning my new tractor, was cleaning up old debris and ran over a 2x4 with 4 nails... I used slime and it worked somewhat (had to add air every few months). Finally, years later, took the tire to a tire shop and they put a tube in for $16... I still have not had to add any air to that tire.
Other tire with no punctures been leaking a little but I'll be due for a new front set of tires before long... I'll deal with adding air for a while.
Bottom line for me, Tubes worked fine.
2008 FORD F-350 SUPER DUTY BUCKET TRUCK (A58214)
2008 FORD F-350...
2000 INTERNATIONAL 9200 (A58214)
2000 INTERNATIONAL...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
UNVERFERTH AUGER FOR GRAVITY WAGON (A52708)
UNVERFERTH AUGER...
EVINRUDE OUTBOARD MOTOR (A58374)
EVINRUDE OUTBOARD...
2006 APPA TL (A55788)
