Ford New Holland 3930 Fuel System
/ Ford New Holland 3930 Fuel System #1
PM Wells
Foothills Of The Blue Ridge NC
98 New Holland 3930-- 95 Massey Ferguson mf 253
Fuel filter was changed and having problems bleeding air from fuel system. This is a late 3930 with the one piece fuel filter and water seperator, and also a fuel shut off solenoid. I am having trouble getting air out of the lines. I read that New Holland had directions on the process to purge air from this system, but can't find it online. Could someone walk me through this process if you will Thanks much.
/ Ford New Holland 3930 Fuel System #2
Start with at least a 1/2 tank of fuel.
-Open the bleeder cap on the fuel filter housing until the air bubbles pretty much stop coming out. Close cap.
-Open the small bleeder screw on the injection pump. 5/16" wrench is needed. Let fuel bleed out until no air bubbles present. Try starting.
-If it doesn't fire at this point, you will need to bleed the injectors.
-With a 5/8" wrench, loosen the injector lines on each injector. Crank the engine over until you don't see air bubbles/foam coming out of injectors. Once solid stream of fuel is seen, tighten the lines and try starting.
If you keep seeing air in the system, you may have left a gasket on the fuel filter head and the new filter is not able to seal correctly.
Thank you, would I need the switch on to open the fuel shut off solenoid. I know it needs to be on for it to run, but does it need to be on to get fuel into the injection pump. I will check the filter to make sure it does not have an extra gasket on the filter.
/ Ford New Holland 3930 Fuel System #4
I don't remember, but turn it to on and then there is no question.
I now have determined that the problem is more than likely to be the injection pump that needs to be rebuilt. I am sending the pump and injectors to D&C Diesel in Ky to have them rebuilt. While he has them I will be cleaning the tank and all lines plus a new filter assembly. I think that will solve the problem when it is all back on the tractor.
/ Ford New Holland 3930 Fuel System #6
D&C Diesel. That would Dudley Carr in Falmouth?
Yes sir, That is Dudley Carr, I really like him and his work.
I sent the injection pump and injectors to Dudley Carr at D&C Diesel to rebuild. I should get them back in a week or so, and hopefully can get the 3930 up and running soon.
Setting the timing on the tractor is pretty simple using the timing marks on the flywheel which are clearly marked. My 98 New Holland 3930 top dead center is set at 29 degrees according to the label on the valve cover and there is a inspection hole just under the tractor with an arrow mark to set by, I turned the engine till 20 degrees was visible then each mark is two degrees up to 30, then back off the flywheel 1 degree to 29. Then lock the pump down with the locking pin through the pump mounting flange before taking any mounting bolts out.
A word of advice, stay away from the New Holland 3930 made in 1998/1999. They are what they call emission tractors with turbos on them. In my opinion New Holland ruined a good tractor by bowing to the green EPA rules.
/ Ford New Holland 3930 Fuel System #10
Other than the Bosch pump makes them a little more finicky/expensive to fix. They are okay, but I agree that emissionized tractors were less than there earlier non-emissionized equivalents.
Forklift (A56857)
Forklift (A56857)
405 (A52706)
405 (A52706)
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2014 Parker Trailer Sales Trailer (A60352)
2014 Parker...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
