Kubota L6060 power loss - SCV issue?
   / Kubota L6060 power loss - SCV issue? #11
I have taken lots more precautions since the $10k repair. I think most of the problems were caused by condensation in the transfer tank which resulted in water in the fuel. Now, I treat every tank with diesel cleaner, I keep closer watch on the water separator, I use water separator filters on the transfer tank.
Also, the L6060 has a 'common rail' fuel system which are a lot more finicky.
Here is a link to the thread I posted about the 10k repair.
My guess would be the fuel filter needs to be replaced again. I have 2 L6060's and have had similar issues.
I think you are probably correct on the fuel filter. My memory seems to have failed me. Picked up both the water separator filter and the main fuel filter today. In changing them out it looks like last time I had only removed and cleaned the separator filter. I could have swore I did both but must have made a mental note on the main filter and never got back around to it. My marker notes on the filter shows it had almost 350 hours on it. Replaced both, reset the code, and roaded the tractor the four miles from my shop back home. No issues on the steeper grades and no loss of power. All seems well.
   / Kubota L6060 power loss - SCV issue? #13
I would say that's good news. Thanks for letting us know.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 KENWORTH T800 (A58214)
2010 KENWORTH T800...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
LOT: (3) Kimball Midwest 40-Hole Hardware Cabinets w/Contents (A59076)
LOT: (3) Kimball...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2017 Komatsu PC490-11 Hydraulic Excavator, S/N A41596, PIN# KMTPC251JHWA41596, Turbo Diesel Engine, (A59076)
2017 Komatsu...
