Tractor overheating
/ Tractor overheating #1
Leonard malone
Kioti ck 25
Just looking for some advice on where to start to find the problem. Thanks
/ Tractor overheating #2
I would start with the most obvious things such as a clogged air filter or radiator screen/fins, fluid levels as well as condition of oil/coolant, fan belt, collapsed radiator hoses. And then move on to more complicated tests.
/ Tractor overheating #4
maybe more info on the working condition that led to overheating.
do you keep routene scheduled maintenance such as items mentioned above?
/ Tractor overheating #5
Does it overheat all the time or just when performing certain tasks? You could be asking the tractor to do more than it was designed to do. You may not be operating it in its optimum power RPM. Perhaps you're trying to do the work in too high a gear. Many things can cause a tractor to overheat which are not cooling system related.
/ Tractor overheating #6
Start by taking off the radiator cap once it has cooled off and make sure there is coolant in the radiator Then check the screen in front of the radiator. Clean if necessary.
/ Tractor overheating #7
As others already said. Back story on what you are doing and what you have done so far to prevent it. Is it boiling over? Is there a screen in front of the radiator to help prevent grass and debris from getting into the fins? Try blowing the radiator out with compressed air. Air is the better choice than washing it out. If is full of fine dirt you turn it into mud if you wash it out with water. Is the thermostat opening? They can fail although it's more common they fail in the open position. Check the radiator hose especially the top to make sure it's not collapsed. Are you seeing any external leaks? Specifically around the head? What is the condition and tightness of the fan belt? Is the water pump okay? Not leaking?
/ Tractor overheating #11
The flooded battery most of you are referring to contain lead. I think I remember that all lead mining in the US was closed down due to pollution and other environmental issues. That plus it is only 3 or 4 battery manufacturers in the US does not help prices, especially when the manufacturers are hit with more regulations.
So all that added together plus the increased transportation cost doesn't make cheap batteries.
/ Tractor overheating #12
Wrong thread?
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
STAINLESS STEEL BAKERS RACK (A63745)
STAINLESS STEEL...
FIXED FIFTH WHEEL ATTACHMENT (A63569)
FIXED FIFTH WHEEL...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Club Car Golf Cart (A64047)
Club Car Golf Cart...
